Static electricity and high voltage?
Static electricity is characterized by high voltage due to the difference in electric charge between two objects, such as a person and the ground. The electric field surrounding a statically charged object can ionize air, allowing charge transfer to an oppositely charged object. A significant electric field strength, approximately 1kV/mm, is required to generate noticeable effects like sparks. The potential difference can range from a single electron's charge to millions of volts in specialized generators.
  • Understanding of electric charge and potential difference
  • Familiarity with electric fields and their properties
  • Basic knowledge of electrostatics principles
  • Awareness of voltage measurement units (Volts)
  • Study the principles of electrostatics on Wikipedia
  • Learn about electric field strength and its implications
  • Explore the construction and operation of a Kelvin Water Dropper
  • Research the applications of static electricity in various fields
This discussion is beneficial for students beginning their studies in electricity, educators teaching electrostatics, and hobbyists interested in experiments involving static electricity.
Taylor_1989
I was just wondering how static electricity has a high voltage. Is it because of the difference of charge between the two objects e.g you and the ground?
Or is it due to the electric field which surrounds an static charged object, so the electric field cause ions to build in the air allowing the charge to travel across to an object of opposite charge, i.e the longer the electric field is allowed to create ions the more voltage?
Different charges on different objects can generate a field in between. Where "different charges" may include non-trivial computations to get the voltage for specific problems.
You need a really high field strength to get this, something like ~1kV/mm. This can happen if you touch good conductors, which generates a small spark.
Taylor 1989, From your questions I guess that you are beginning your studies of electricity. Static electricity is, as you say, the difference in potential between two objects and is measured in Volts. The amount of charge differences can be over the whole range from the smallest (that would be one single electron's charge) difference all the way up to Millions of Volts difference in some special generators.
I suggest you read and study these two Wiki pages first:
http://en.wikipedia.org/wiki/Static_electricity
http://en.wikipedia.org/wiki/Electrostatics
In the second one you will see a diagram that I think is excellent for visualizing what electrostatic charged objects would look like if we could see the charge distribution:
http://en.wikipedia.org/wiki/File:Electrostatic_induction.svg
Finally, for tons of fun, you could build a "Kelvin Water Dropper" which uses drops of water to transfer charge. Quite high Voltages can be made with this simple device anyone can make at home or in the lab.
http://www.eskimo.com/~billb/emotor/kelvin.html
If you have more questions or some doubts, come right back here and post them!
Cheers,
Bobbywhy
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 21 ·
