Hilbert space formulation for non-quantum mechanics?
The discussion revolves around the potential application of Hilbert space formulations to classical mechanics, distinct from its established use in quantum mechanics. Participants explore whether classical systems can be represented using vectors in a Hilbert space, particularly in the context of pedagogical value and mathematical parallels.
  • One participant suggests using Hilbert space to represent a classical bead on a wire, proposing a formulation with four state vectors based on position and momentum.
  • Another participant notes that Hilbert space is a mathematical concept without inherent physical meaning, primarily utilized in quantum mechanics because it fits the framework of that theory.
  • Concerns are raised about the arbitrary nature of the proposed state vectors, as the classification depends on the chosen coordinate system rather than the physical behavior of the system.
  • One participant mentions that classical mechanics does not involve superpositions of states, unlike quantum mechanics, and speculates that a Hilbert space formulation for classical mechanics might be overly complex and lack insight.
  • Another participant draws a parallel between classical mechanics and quantum mechanics through Sturm-Liouville theory, suggesting that while mathematical methods may overlap, a direct physical analogy may not exist.
  • There is a discussion about the frame-dependence of certain measurements in quantum mechanics, contrasting it with the proposed classical formulation.
Participants express differing views on the feasibility and utility of applying Hilbert space to classical mechanics. While some see potential in the exploration, others question the validity and practicality of such a formulation, indicating that the discussion remains unresolved.
Participants acknowledge limitations in their understanding of the implications of Hilbert space in classical contexts, as well as the dependence on definitions and the potential complexity of the proposed formulations.
jjustinn
Note: I am NOT talking about the classical limit of quantum mechanics, where in the limit of numbers that are large compared to h the average values approach the classical values, nor am I talking about Lagrangin/Hamiltonian mechanics in phase space; I am talking about using vectors with classical-scale values in a Hilbert space INSTEAD of classical mechanics.
For example, take a bead constrained to move on a wire (so its position and momentum can be take values on the x axis), and say for this experiment we are interested if it is to the left of the origin,or at/to the right of the origin, and similarly for the momenta; therefore, our Hilbert Space contains four possible state vectors: (x<0, p<0), (x≥0, p<0), (x<0, p≥0), (x≥0, p≥0), and since it is a classical system, it will ALWAYS be in an eigenstate of the position/momentum operators, with two eigenvalues each.
It seems like a formulation like this would have great pedagogical value, since the results obtained can be compared to everyday experience (or to those calculated via the more traditional classical formalists-eg F=ma)...that is, supposing it works. I see no reason it shouldn't, but I'm having trouble wrapping my mind around it enough to work out a sample problem to test it out.
So -- does anyone know of any treatments of this, either online or in the literature? Or perhaps a simple reason why there wouldn't be any such treatments (eg “it won't work because...”)?
Thanks -
Justin
Hilbert space in mathematics is a well defined concept, essentially an extension of Euclidean space to infinite dimensions. There is no physics involved per se.
Physics uses the concepts of Hilbert space in quantum mechanics because it fits.
Right -- IIRC a Hilbert space is just a Euclidean space with an inner product, or something similar...but when used in the context of quantum physics, it has a very specific meaning (which I am probably misstating): it is an infinite-dimensional vector space, with one dimension for each degree of freedom, so that each vector contains the complete state for a given particle. For example, if you are only interested in spin, and your system contains two electrons, your Hilbert space would contain just two dimensions (particle label, spin state) and four states (or do indistinguishable states not get recounted?).
But even beyond that, in the context of QM, the "Hilbert space formulation" also implies that observable values a obtained by finding the eigenvalue of a linear operator on the state vector.
So that's what I was looking for -- a formulation of classical physics using *that* formalism, which happens to use vectors in a Hilbert space.
My exposure to Hilbert space was through the mathematics. You probably know a lot more about the physics application than I do.
Unfortunately, mine was through Wikipedia and intro QM textbooks (seems in more advanced books it doesn't even get mentioned), so I'm a total dilettante.
In classical mechanics there are no superpositions of states. In a Hilbert Space there can be superpositions. I can't state this with certainty, but I would bet that if you could find a Hilbert Space formulation of Classical Mechanics, it would be so messy as to provide no insight.
The state vectors you gave in your example seem rather arbitrary to me. The difference between x < 0 and x ≥ 0 depends on the origin of your coordinate system, not on the behaviour of the bead on the wire. This seems fundamentally different from a notion like "the spin of an electron", which doesn't depend on how fast your reference frame is rotating!
In classical physics there are plenty of situations where a differential equation plus its boundary conditions generates an eigenvalue problem, and the possible solutions to the DE are linear combinations of the eigenvectors. The general study of this (independent of particular physical problems) is Sturm-Liouville theory, which predates quantum mechanics by half a century or more - and in fact the eigenpairs form the basis functions of a Hilbert space ...
I'm not sure whether that is where you are heading, but there seems to be an analogy between the mathematical methods used in QM and classical mechanics here, even if there isn't really a physical analogy.
AlephZero said:
The state vectors you gave in your example seem rather arbitrary to me. The difference between x < 0 and x ≥ 0 depends on the origin of your coordinate system, not on the behaviour of the bead on the wire. This seems fundamentally different from a notion like "the spin of an electron", which doesn't depend on how fast your reference frame is rotating![\quote]
If I'm not mistaken, while the total spin is frame-independent, the measured spin about any axis isn't -- but even putting that aside, there are position operators in QM that operate exactly like that example -- where the value obviously depends on the chosen frame, but would transform appropriately under a change of frame. The more common formulation breaks the axis into an infinity of infinitesimal-sized chunks rather than just two chunks, but to get a meaningful probability, you would have to integrate over a finite area...but anyway...
That sounds like exactly where I was heading. I have seen Sturm-Liouville crop up in discussions of “Hilbert Space Methods” in a classical context, but always took it to be sort of mechanistic techniques for solving DEs...I'll have to look at that.
  • · Replies 16 ·
  • · Replies 61 ·
  • · Replies 0 ·
  • · Replies 59 ·
  • · Replies 16 ·
