Affordable Water Detector for Plastic Tanks - Expert Tips
  • Thread starter Thread starter AR1234
    Detector Water
The discussion revolves around building an affordable water detector for plastic tanks, focusing on methods that do not alter the water's chemistry. Participants explore various approaches to indicate water presence at a certain level in the tank.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests a simple float switch as a potential solution, noting it can be pre-tuned to trigger with minimal water level changes.
  • Another participant expresses concern about float switches getting stuck and requests further insights on reliable implementations.
  • A different approach is proposed involving a ping-pong ball attached to a mini-lever switch, with a note on waterproofing considerations based on the switch's placement.
  • Another participant shares an experimental method using two metal strips on a non-conductive surface, describing how they could function as a leak detector when water bridges the gap between them.
Participants present multiple competing views on the best method for detecting water, with no consensus on a single approach or solution.
Some methods discussed may depend on specific conditions such as water turbulence or the placement of components, which could affect their reliability.
AR1234
I'm new to the forum, and will much appreciate your advice.
Looking to build a cheap water detector, that will not change the chemistry of the water.
It should simply indicate if water is touching it (if water reach a certain level in a tank made of plastic).
Many thanks
Al
Hi, AR.
Although I don't know the scale of your project, a simple float switch should suffice. As long as there is no turbulence in the water, you can pre-tune it to the point that a mm or so of additional water will trigger it.
Any reference or direction for a "simple float switch"?
My limited experience with floats was that they sometimes remain stuck; any insight will help.
Many thanks,
Al
Well, I'm no expert on this by any means. Something like a ping-pong ball glued to the end of a mini-lever switch (waterproofed with latex or silicon) would work quite well.
edit: The waterproofing isn't necessary if you can be sure that the switch will remain dry.
In some experimental submersible sonar units we used two metal strips glued very close together in parallel on a non-conductive surface. Each was connected by a wire to a detector circuit. To one we applied +5 Volts and the other became the input to a comparator. If water intruded (leaked in) it conducted enough of that +5 Volts to switch the comparator to "true= leak".
  • · Replies 39 ·
17K
  • · Replies 0 ·
  • · Replies 152 ·
12K
