How to calculate entropy for a system
  • Context: Graduate
  • Thread starter Thread starter CraigH
    Entropy System
The calculation of entropy for a system can be accurately measured using the thermodynamic definition, represented by the equation S = ∫(dQ/T) + S0, where S0 is the entropy at absolute zero. This definition requires knowledge of the heat capacity of the substance as a function of temperature. The formula S = ln(the number of possible arrangements) is applicable in specific contexts but does not universally apply to all systems. Understanding the number of possible arrangements is crucial for calculating entropy, especially in complex systems.
  • Understanding of thermodynamic principles
  • Familiarity with the concept of heat capacity
  • Knowledge of statistical mechanics
  • Basic calculus for integration
  • Study the relationship between heat capacity and temperature in thermodynamics
  • Explore statistical mechanics and its application to entropy calculations
  • Learn about the concept of microstates and macrostates in thermodynamic systems
  • Investigate advanced entropy calculations in complex systems
Students and professionals in physics, thermodynamics researchers, and anyone interested in the quantitative analysis of entropy in various systems.
CraigH
How can you acuratley measure this? I can't see how you can give randomness a number? I've seen in some places that S = ln(the number of possible arangments) Is this true in all cases? But how can you measure the number of possible arangements?, it seems imposible to calculate the entropy for a complicated system.
Thanks
Science news on Phys.org
CraigH said:
How can you acuratley measure this? I can't see how you can give randomness a number? I've seen in some places that S = ln(the number of possible arangments) Is this true in all cases? But how can you measure the number of possible arangements?, it seems impossible to calculate the entropy for a complicated system.
Thanks
The thermodynamic definition of entropy S at a temperature T is:
[itex]S = \int_{0}^T dS + S_0 = \int_{0}^T \frac{dQ}{T} + S_0[/itex]
where S0 is the entropy at absolute zero which is not really defined but you can take it to be 0. Strictly speaking, it is only zero for molecular structures that can have only one microstate at absolute zero.
In order to calculate this integral, you just need to know the heat capacity of the substance as a function of temperature.
AM
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 20 ·
