Stress and strain, maximum applied force before permanent deformation/breakage
The discussion revolves around calculating the maximum longitudinal force that a bone can withstand before breaking, focusing on the relationship between compressive stress and the geometry of the bone modeled as a solid cylinder.
  • Participants explore the use of different stress equations, initially attempting to apply torque calculations before shifting focus to axial stress and cross-sectional area. Questions arise regarding the correct interpretation of the problem and the appropriate formulas to use.
The discussion is ongoing, with some participants providing guidance on the correct approach to calculating the maximum axial load. There is a recognition of the need to clarify the distinction between bending stress and axial stress.
Participants note potential ambiguities in the problem statement regarding the type of stress being addressed, as well as the need for precise definitions and assumptions related to the geometry of the bone.
wolfpack11
Compute the maximum longitudinal force that may be supported by a bone before breaking, given that the compressive stress at which bone breaks is 2.00e8 N/m^2. Treat the bone as a solid cylinder of radius 1.55 cm. The attempt at a solution
I tried using the equation Max Torque = pi/4 * (r^3) * max stress. Plugged in 0.0155 m for "r" and 2.00e8 N/m^2 for max stress, got 585 N*m for torque, then divided again by 0.0155 m to get the Force (377000 N). This answer wasn't accepted into webassign. What am i missing in the problem solving?
You are calculating max torque or moment due to bending stresses, but the problem is asking, perhaps not too clearly, for max axial (longitudinal) load based on allowable axial stress. Instead of using bending stress = M/S, try using axial stress = P/A.
Ok. If P is the compressive force, and A is the cross-sectional area that the force is applied to, I would think that A= ∏*r^2 for the surface of the cylinder. Then, multiplying A by the maximum stress 2e8 N*m^2 would yield P?
14K
10K
