Damped Driven Harmonic Oscillator
The discussion focuses on solving the damped-driven harmonic oscillator by rewriting the differential equation in terms of a complex solution z(t) = Ce^{iωt}. The complex constant C can be expressed as Ae^{-iδ}, which is valid for any complex number due to its polar representation. The relationship between A and δ is clarified through the equation f₀e^{iδ} = A(ω₀² - ω² + 2iβω), leading to δ being expressed as δ = tan^{-1}(2βω/(ω₀² - ω²)). The conversation also emphasizes the importance of understanding Argand diagrams and trigonometric representations of complex numbers to grasp these concepts fully. Overall, the participants provide insights into the mathematical foundations necessary for solving the oscillator's equation.
AbigailM
Just have a few questions regarding the method of solving the damped-driven harmonic oscillator.
Once we have rewritten the differential equation in terms of z and it's derivatives, we try a solution z(t) = Ce^{i \omega t}. When we sub in z and it's derivatives we then rewrite the complex constant C as Ae^{-i \delta}. My book says that we can do this for any complex number. Why is this?
When we solve for A and sub that into C=Ae^{-i \delta} we find
f_{0}e^{i \delta}=A(\omega_{0}^{2} - \omega^{2} +2i \beta \omega).
My book says we can then rewrite \delta as \delta=tan^{-1}\left(\frac{2\beta\omega}{\omega_{0}^{2}-\omega^{2}}\right). Could someone please explain this? The right triangle explanation is confusing me.
Thank you all.
I asked a question about this on another forum. I never got an answer, but I know the answer involves taking the laplace transform...
we can write any complex number in the form z = re^ig
thus they have just written that complex number in a convenient form for them.
that g (which i am using as my argument for the exponent) is just the angle in the polar representation of a complex number. thus it can be calculated from trigonometry if we know the adjacent and opposite sides of the triangle. this is where the arctan thing comes in.
Do you know how to draw Argand Diagrams? if so, do that for every complex number you see in the derivation and hopefully your trig training will kick in and help you.
hope that helps mate.
Do you know about the trigonometric representation of complex numbers and Euler's formula?
For you case, it will be:
e^{-i \delta}=cos\delta - i sin\delta
You can use this to solve your equation and find δ.
Awesome that makes sense, I think I'm clear on now. Thank you all for the help!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
