Do all radiations work on solar panels?
Photovoltaic cells can convert specific frequencies of light into electrical energy, making them compatible with lasers if the laser's frequency falls within the operational range of the cells. However, using a laser to power solar panels results in significant energy losses, as the energy required to operate the laser exceeds the energy produced by the solar cells. Additionally, common light sources like incandescent and fluorescent lamps can also effectively power solar panels, as demonstrated by solar-powered calculators that function indoors.
  • Understanding of photovoltaic cell operation
  • Knowledge of light frequency and wavelength
  • Familiarity with energy conversion efficiency
  • Basic principles of laser technology
  • Research the efficiency of different photovoltaic cell types
  • Explore the impact of light frequency on solar panel performance
  • Investigate energy loss mechanisms in laser-based energy transfer
  • Learn about alternative light sources for solar energy applications
Engineers, renewable energy researchers, and anyone interested in optimizing solar energy systems and understanding the interaction between light sources and photovoltaic technology.
Karimspencer
Lets say you make a huge laser , can i work on Solar Panels to convert it to electrical energy.
Science news on Phys.org
Photovoltaic cells can use some frequency ("color") range only. If the laser is within this range, they can work. However, keep in mind that this is just a way to transfer energy with significant losses - you need more energy to power the laser than the cells will give you.
Even a simple incandescent and fluorescent lamp will work. See "solar" powered pocket calculators. They work indoors too, don't they?
  • · Replies 38 ·
  • · Replies 16 ·
