Electric circuit - Why is the switch needed in this capacitor circuit?
The discussion centers on the necessity of a switch in a capacitor circuit. It is established that a capacitor only charges when the switch is closed due to the extremely small capacitance of the switch, which is significantly lower than that of a standard capacitor. The switch's capacitance is calculated using the formula C = ε₀(A/d), resulting in values well under 10^-15 F. Additionally, the potential difference (V) between two points in the circuit remains nearly constant, with only a negligible voltage drop across the connecting wires.
  • Understanding of basic electric circuits
  • Familiarity with capacitor behavior and capacitance calculations
  • Knowledge of potential difference and voltage in circuits
  • Basic principles of battery operation and electron flow
  • Study the principles of capacitance and its applications in circuits
  • Learn about the role of switches in electrical circuits
  • Investigate the effects of wire resistance on voltage drop
  • Explore advanced capacitor types and their characteristics
Electrical engineering students, hobbyists building circuits, and anyone interested in understanding capacitor functionality and circuit design.
Sogan
electric circuit -- Why is the switch needed in this capacitor circuit?
Hi,
I have two questions with respect to the picture in the attachment.:
1)
I have read, that the capacitor become charged, when the switch is closed. All right, but why the capacitor doesn't became charged before the switch is closed?
At least the left conductor is connected with the positive pole of the battery, so I thought the electrons will leave the left conductor.
2)
In the picture we can see a potential difference V between two points of the electric circuit. Is the potential V always the same between two points, whereas one Point is between the left conductor and the "+"Pole and the other one is between the right conductor and the "-"Pole?
Regards!
Welcome to PF!
Hi Sogan! Welcome to PF! :smile:
Sogan said:
1)
actually, it is, very very slightly …
a switch is just a capacitor with a very small plate area (A) and a very large separation (d)
since capacitance is 8.85 10-12 A/d, that means that the capacitance of a switch is extremely small (well under 10-15 F)!`
(actually the A/d formula really only applies if A is much larger than d2, but you get the idea)
capacitance is the ability to separate charge, and a switch can separate hardly any charge
if a switch and an ordinary capacitor are in series, the charge across both must be the same
for all practical purposes, the charge (across both the capacitor and the switch) can be considered zero :wink:
why can't the battery "pump" electrons onto the nearer plate of the capacitor?
a battery is electrically neutral, it doesn't supply electrons, it can only shunt them … it would have to take an electron from the switch, and the battery simply doesn't have enough strength to do that! :smile:
2)
more or less …
the only difference would be the (extremly small) voltage drop across the extra bit of wire :wink:
  • · Replies 21 ·
