Dynamical System Analysis using Mathematica
The discussion focuses on the analysis of a dynamical system using Mathematica, specifically addressing the process of finding equilibrium points from a set of autonomous ordinary differential equations (ODEs) and subsequently calculating the Jacobian matrix and its eigenvalues.
  • One participant describes their approach to finding equilibrium points using NSolve on two autonomous ODEs and obtaining five solutions.
  • The same participant constructs a Jacobian matrix in terms of the variables x and y and seeks assistance in substituting the equilibrium values into this matrix to compute eigenvalues.
  • Another participant explains how to extract values from the NSolve output, providing a method to access the solution values for substitution.
  • A further suggestion is made to apply a mapping technique to substitute values into a matrix, demonstrating this with a sample matrix and solutions.
  • One participant acknowledges the usefulness of the suggested method and notes they used a similar approach.
Participants generally agree on the methods for extracting solutions and substituting them into matrices, but the discussion does not resolve the overall approach to calculating eigenvalues from the Jacobian matrix.
There are potential limitations regarding the clarity of the Jacobian matrix construction and the specific form of the ODEs, which are not fully detailed in the discussion.
Zhamie
Hello there,
Let me start from the beginning. I have dynamical system described by two autonomous ODEs (eqn1, eqn2). To find equilibrium points I used NSolve[{eqn1 == 0, eqn2 == 0}, {x, y}] which gave me 5 solutions in a form {{x->2, y->0},{...},...}. I also constructed Jacobian matrix using M={{D[eqn1,x], D[eqn1,y]},{D[eqn2,x],D[eqn2,x]}} which is written with x and y. Next I need to calculate this Jacobian matrix substituting solutions from NSolve function to find its eigenvalues. So I should have 5 matrices with corresponding eigenvalues. How can I achieve this? The problem is to substitute values from the solution to the matrix.
I will appreciate any help.
I understood how to extract NSolve output. For this purpose you need to write soln=NSolve[...], then to access the solution values of this function x /. soln[[1]], y/.soln[[1]] (this corresponds to the 1st solution)
So next step will be to substitute those values to the matrix written in terms of x and y. Any ideas?
Can you apply this method to your problem?
In[1]:= mat={{x,y},{x+y+1,2x-3}};
sols={{x->1,y->3},{x->2,y->4}};
Map[mat/.#&,sols]
Out[3]=
{{{1, 3},
{5, -1}},
{{2, 4},
{7, 1}}}
Map[mat/.#&,sols]
Out[3]=
{{{1, 3},
{5, -1}},
{{2, 4},
{7, 1}}}
Thank you. I used quite similar way of doing this.
