Need help with numerical lifting line method
The discussion focuses on coding the numerical lifting line method from Warren F. Phillips' "Mechanics of Flight," specifically clarifying the concept of the directed differential vortex length vector. This vector represents the segment of the horseshoe vortex bound to the lifting surface, connecting two points along the wing's quarter-chord, and does not require differentiation. Participants explain that the nodes for these vectors should be chosen along the quarter-chord of the wing, typically using a cosine distribution for accuracy. Additionally, the relaxation factor in Newton's method is described as a multiplier that adjusts the correction value in iterative calculations, allowing for more controlled convergence. Overall, the conversation emphasizes understanding the geometry of the vortex model and the iterative process in numerical methods.
Dmalyuta
Dear all,
I am following Warren F. Phillips' book "Mechanics of Flight" (2nd edition) and am trying to code the numerical lifting line method outlined by him starting on page 96 of Chapter 1.
I will write the code in Matlab, but what is preventing me from doing so is a few variables within the said method which I am confused about how to find.
Variable number one is dli, which is defined as the "directed differential vortex length vector"; the boundary of my knowledge of vector calculus is differentiating vectors. Now, the method does not require anything beyond that- but I do not know what the vortex length vector even is, and how one finds it.
Question number two is about Newtons method. What is a relaxation factor?
As I write my code, I might have more questions and I will probably ask them here. For now, I would appreciate your help in explaining to me what variable number one is/how it is found!
For reference, variable number one is cited to come from Saffman 1992- I have the book, but cannot find anything on the variable in it (300+ pages, non-searchable format). The method itself is referenced to come from a more detailed account on it in Phillips and Snyder 2000.
THANK YOU!
I am not certain what the directed differential vortex length vector is and i do not have that book but here is what I think it might mean. When using the lifting line method you model the wing as a series of horseshoe vortices. Each horseshoe vortex is made up of 2 semi infinite vortex filaments and one finite vortex filament. I suspect that this variable represents the length and direction of the finite vortex element. Therefore it can be determined based on the geometry of the problem. If you show me the entire equation I may be able to help more.
Unfortunately I can't help with the relaxation factor.
Hi randomguy!
Thank you for the response; I think you have set me on the right track.
However!
I am only familiar with differentiating vectors which have a variable in them; e.g. the derivative of [t; 2t2; 3t] will be [1; 4t; 3]. Where are the variables in the directed differential vortex length vector? I understand the vortex length vector as the difference of the position vectors of the two nodes of the bound segment running along the quarter-chord of the wing- so then how do you differentiate it? And what does 'directed' mean?
If you have access, the paper on the numerical lifting line method is called 'Modern adaptation of Prantl's classical lifting-line theory' by Phillips and Snyder/2000/AIAA Journal of Aircraft issue #4.
Waiting for a reply! :)
I think it refers to adding less than the full correction value. Newton's method is iterative where the new estimate is the old estimate plus a correction value:
xn+1 = xn + α*Δxn
Alpha is the relaxation factor. Nominally it has a value of 1 so often isn't shown. But, it can be less (or greater) than 1.
The differential length vector is the part of the horseshoe vortex that is bound to the lifting surface, exactly what RandomGuy88 said. This vector will not be defined by a formula that you take the derivative of, it is just a vector connecting two points. To do Phillips method you choose n points which span the wing to be the "nodes", these are usually along the quarter-chord. You also choose n-1 "control points", 1 in between each successive pair of nodes. There will then be n differential length vectors connecting the nodes on either side of each control point. You don't need to take the derivative of anything, you just choose where the nodes go (you should eventually use the cosine distribution Phillips describes but for now just make them equally spaced along the quarter-chord from wing-tip to wing-tip) and then you can easily calculate these "differential" vectors.
Venus does not have a magnetosphere, so the Galactic Cosmic Rays (GCRs) environment shall be much worse than in a LEO environment. Looking to the std radiation models for Venus, the standard radiation-hard space level electronic component with tested immunity LET = 85 MeV-cm2/mg seems not enough, so, for example, a 1cm2 Si die will suffer considerable flux above this level during a long mission (10 years for example). So, the question is, usually we are not paying attention to latch-up...
Due to the constant never ending supply of "cool stuff" happening in Aerospace these days I'm creating this thread to consolidate posts every time something new comes along. Please feel free to add random information if its relevant. So to start things off here is the SpaceX Dragon launch coming up shortly, I'll be following up afterwards to see how it all goes. :smile: https://blogs.nasa.gov/spacex/
Thread 'SpaceX Starship development: 7th flight January 10'
Watch the progress live This is a fully stacked Starship (top) and Super Heavy (bottom). A couple of too-small-to-see cars near the bottom for scale, I also added a Saturn V and the Statue of Liberty for comparison. 120 meters tall, about 5000 tonnes when fully fueled. Twice the mass and over twice the thrust of Saturn V. The largest rocket ever built by mass, thrust, height, and payload capacity. N1 had the largest diameter.[/size] But its size is not the revolutionary part. It is designed...
