Understanding RF Absorption by Metals in RFID Testing
Aluminum significantly affects RFID waves in the 860-960MHz range, primarily reflecting and absorbing signals, leading to dead zones in testing environments. Specifically, aluminum blocks waves at 900MHz with minimal loss and zero propagation. The interaction of RFID signals with aluminum is complex due to the wavelength of 0.3m, which causes diffraction, making it essential to consider the placement of metal structures near antennas. Proper antenna setup, including the use of left-hand and right-hand circular polarization, is crucial for optimal performance.
  • Understanding of RFID technology and frequency ranges (860-960MHz)
  • Knowledge of antenna design and placement principles
  • Familiarity with circular polarization concepts in RF communications
  • Experience with signal reflection and absorption properties of materials
  • Research the effects of metal structures on RFID signal propagation
  • Learn about antenna design, specifically Yagi antennas and their components
  • Explore techniques for minimizing dead zones in RFID testing environments
  • Study the principles of circular polarization and its impact on antenna performance
RFID engineers, antenna designers, and professionals involved in RFID system testing and optimization will benefit from this discussion.
kirr45
Hi everyone.
I was wondering how badly aluminum affects RFID waves (860-960MHz)? Do they completely absorb, reflect, combination of the two? I'm having issues with my testing of RFID. I'm getting some dead zones and I think it could be because of the portal frame the antennas are mounted on. I have an aluminum frame connected to a 6 inch bracket antenna mount, then there antenna. Also, if you know about left hand and right hand circular polarization and in which setup they cancel each other out, that would be a big help. For example, if you have two of the same propagating, or two of the opposite propagating antennas, in which setup would be best, and which would be the worst(cancel each others performance)?
Thank you
Aluminium blocks completely waves at 900MHz, with reflection, little loss and exactly zero propagation through it.
BUT things are complicated because the wavelength (0.3m) isn't very small as compared with your objects, so your radio waves are diffracted (say, like sound goes around obstacles) and do not behave at all like light does. So you cant' get a simple answer, alas.
kirr45 said:
Hi everyone.
Thank you
Welcome to the PF.
You should not have any metal near your antenna, unless it is explicitly part of the antenna structure (like the reflector and director elements of a directional Yagi antenna), or part of the antenna mast/support that is out of the antenna's pattern.
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 47 ·
  • · Replies 152 ·
12K
  • · Replies 0 ·
