How much force would it require to obliterate a baseball bat?
  • Context: Undergrad
  • Thread starter Thread starter promeus
    Baseball Force
The discussion revolves around the question of how much force or energy is required to break or obliterate a standard-sized baseball bat made of maple, specifically focusing on the use of a hammer as the tool for this task. The conversation includes considerations of theoretical calculations and empirical measurements.
  • One participant inquires about the force or energy needed to break a maple baseball bat and requests a calculation process in joules.
  • Another participant suggests that calculating the required force accurately is challenging and may need to be determined experimentally rather than through formulas.
  • A participant proposes a model assuming the bat is a maple cylinder with specific dimensions and density, seeking guidance on how to proceed with calculations.
  • It is noted that calculating breaking force under a slowly applied load is straightforward, but the complexities of an impact with a very short duration necessitate empirical measurements.
  • A link to a video is provided, presumably related to the topic, but its relevance is not discussed further.
Participants do not reach a consensus on a specific method to calculate the force or energy required, indicating that multiple competing views and approaches remain in the discussion.
The discussion highlights the limitations of theoretical calculations in the context of dynamic impacts and the need for empirical data, but does not resolve the specific assumptions or mathematical steps involved.
promeus
Just a simple question,I would like to know how much force or energy it would take to break or obliterate a standard sized baseball bat made of maple.
A hammer would be the tool for this.
If possible could you explain the process used to calculate this and post the energy in joules?
There's really no accurate or easy way to calculate this using formulas. It pretty much has to be determined experimentally.
Okay,in that case let's assume that the bat is a maple cylinder and let's assume the diameter is 2.75 inches and that the length of the thick part is 40 inches. The cylinder is also completely made of maple. With the density being 436 kg^3 where would i go from here on out to determine the energy required to break the bat.
It would be fairly easy to calculate breaking force for a slowly applied load. But an impact of very short duration greatly complicates matters. Hence the need for empirical measurements.
https://www.youtube.com/watch?v=QFlEIybC7rU
  • · Replies 39 ·
  • · Replies 26 ·
10K
