Where Does the Formula for L_0 in Audio Output Transformers Come From?
The discussion centers on the derivation and understanding of the formula for L_0 in audio output transformers, including its components and the implications of using different units. Participants explore the relationship between inductance, magnetic path length, and the geometric factors involved in the calculations.
  • One participant seeks clarification on the origin of the formula for L_0, referencing a source (RDH4) and asking about the magnetic path length (l).
  • Another participant suggests that the formula can be expressed as L = μμ₀N²A/l, where μ₀ is approximately 1.26E-6 H/m, and discusses the conversion from meters to inches affecting the constant used.
  • There is a question about the value of 3.2E2 in the formula, with participants discussing how the conversion to inches impacts the use of μ₀.
  • Some participants clarify that the magnetic path length (l) is given as 4.5 inches, which is identified as the mean flux path length.
  • One participant proposes a modification to the formula for L_0, suggesting it should involve N²/l² instead of N/l, based on the relationship between turns per unit length and total turns.
  • Another participant counters that the equation for the solenoid provided is for inductance per unit length, not total inductance, and discusses the relationship between total inductance and inductance per unit length.
  • A participant shares their equivalent circuit diagrams and expresses disagreement with the derivation presented in a referenced book, indicating a difference in approach to the equivalent circuit design.
Participants express differing views on the correct formulation of L_0 and its components, particularly regarding the use of N/l versus N²/l². There is no consensus on the derivation of the equivalent circuit, as some participants challenge the book's approach while others reference it as a source of agreement.
Discussions include various assumptions about unit conversions and the definitions of terms like magnetic path length and turns per unit length. The implications of these assumptions on the derived formulas remain unresolved.
yungman
I am reading audio output transformers. This is a paragraph from RDH4 and I don't understand where the formula of [itex]L_0\;[/itex] come from. Please see attachment.
It looks like it's just [itex]L = \mu \mu_0 N^2 A/l[/itex] where [itex]\mu_0 \simeq 1.26 E-6[/itex] H/m is folded in with the conversion from meters to inches to give the combined constant of 3.2E-8.
uart said:
It looks like it's just [itex]L = \mu \mu_0 N^2 A/l[/itex] where [itex]\mu_0 \simeq 1.26 E-6[/itex] is folded in with the conversion from meters to inches to give the combined constant of 3.2E-8.
Thanks for the reply. What is the magnetic path l?
[tex]L_0=\frac {3.2A\mu N^2}{10^8\times l}[/tex]
Also where is 3.2EE2 come from. [itex]\mu_0\;[/itex]=1.256EE-6 won't get 3.2EE2.
Thanks
Alsn
Thanks
Alsn
No, the geometric factor A/l just has units of length. In SI units you use m^2 and m to give A/l in meters. Then of course you use [itex]\mu_0[/itex] in H/m (1.26E-6 H/m).
If however you use inches for A/l then you'll need [itex]\mu_0[/itex] in H/in, so approx divided by 39.4 to give 3.2E-8
Thanks, so it's just going from meter to inches.
So what is the path length [itesx]l[/itex]? It was given 4.5 inches, where is this come from? Is this the length of the coil?
Yeah, it's the mean flux path length. :smile:
Thanks Uart, you are of big help.
Actually I have another question:
We know for solenoid, [itex]B=\mu_0\mu n I\;\hbox{ where n is number of turns per unit length.}[/itex]
So [itex]L=\mu_0\mu n^2 A \;\hbox{ where A is the cross section area of the solenoid.}[/itex]
The equation in the article, N is the total number of turns in the given length. so:
[tex]n=\frac N l\;\Rightarrow\; n^2=\frac {N^2}{l^2}[/tex]
With that [itex]L_0\;[/itex] should be:
[tex]L_0= \frac {3.2A \mu_0\mu}{10^8}\frac{N^2}{l^2}\;\hbox{ instead of }\;L_0= \frac {3.2A \mu_0\mu}{10^8}\frac{N^2}{l}[/tex]
No, the equation you post for the solenoid is not for the total inductance, it is for the inductance per unit length. It should read :
[tex]\frac{L}{l}=\mu_0\mu n^2 A[/tex]
Thanks, do you go to sleep? I put in my sleeping in between these posts and you're still here!
So basically the total inductance is take the inductance per unit length times the length:
[tex]L_0= \frac {3.2A \mu_0\mu}{10^8}\frac{N^2}{l^2} \times l \Rightarrow \; L_0= \frac {3.2A \mu_0\mu}{10^8}\frac{N^2}{l}[/tex]
I have a different question, below is the equivalent circuit from the book: The first image is the part in question about the input impedance. The middle picture is the equivalent circuit at different frequency from the book.
The last picture on the right is my equivalent circuit. The top is the equivalent circuit of the real transformer.
(1) is the equivalent circuit refer to the primary.
(2) is the low frequency equivalent.
(3) is the equation of RA using my equivalent circuit which is different from the book in the first image.
(4) is the high frequency equivalent.
As you can see, the way I draw the equivalent circuit is different from the book, I don't think I can agree with the derivation of the book in the first image on the left. Even the equivalent circuit from the book Handbook of Transformer Design and Application by Flanagan and Wikipedia agree with me as in (1) of my drawing:
http://en.wikipedia.org/wiki/Transformer
Anyone?
  • · Replies 39 ·
  • · Replies 25 ·
