How can I solve matrix problems in MATLAB using symbolic variables?
  • Context: MATLAB
  • Thread starter Thread starter Sadeq
    Matlab Matrix
The discussion revolves around solving matrix problems in MATLAB using symbolic variables. Participants explore issues related to defining and manipulating matrices that contain both numeric and symbolic elements, as well as questions about the behavior of MATLAB's symbolic toolbox.
  • One participant describes an issue where they define a symbolic variable EI and attempt to multiply it by a numeric matrix B, but encounter problems when trying to assign this result to another matrix A.
  • Another participant requests the original code to better understand the problem.
  • Several participants discuss the implications of using symbolic variables in MATLAB, questioning whether all variables need to be declared as symbolic for the symbolic processor to recognize them.
  • There are inquiries about the nature of the symbolic variable EI, with some participants suggesting it is simply a symbolic representation rather than a special function.
  • One participant suggests that the failure occurs when trying to mix numeric and symbolic types within the same matrix.
  • A suggestion is made to convert the entire matrix to symbolic before assigning individual symbolic entries to avoid issues.
Participants express varying levels of understanding regarding the behavior of symbolic variables in MATLAB, with no consensus on the best approach to resolve the issues raised. Multiple competing views on how to handle symbolic and numeric matrices remain unresolved.
Limitations include potential misunderstandings of MATLAB's symbolic processing and the specific requirements for variable declarations. The discussion does not resolve the underlying issues related to mixing symbolic and numeric data types.
Readers interested in MATLAB programming, particularly those working with symbolic mathematics and matrix manipulations.
Sadeq
i have 2 simple MATLAB questions
first when i have two matrices
the first one is empty and the second one conatins numbers
i can
Say A=B
SO THE VALUE OF B BECOMES INSIDE A
BUT MY QUESTION I JUST DEFINE SYMS EI
and multiply it by B
bUT When itry to put Put B in A
IT DOENST WORK
COULD ANY ONE HELP PLEASE
THE SECOND QUESTION , WHEN i make transpose for matrix it gives me conject, so how can i deal with this
thank
i can
Say A=B
IT DOENST WORK
thank
I have no idea what you're asking.
Also, this should be posted in the section that deals with Matlab and Mathematica, etc. I am moving your post to that section, but will leave a forwarding link.
Please post your code.
FIRST QUESTION
clc
clear all
T=0*pi/180;
A12=[(cos(T))^2 cos(T)*sin(T) -(cos(T))^2 -cos(T)*sin(T); cos(T)*sin(T) (sin(T))^2 -cos(T)*sin(T) -(sin(T))^2;-(cos(T))^2 -cos(T)*sin(T) (cos(T))^2 cos(T)*sin(T);-cos(T)*sin(T) -(sin(T))^2 cos(T)*sin(T) (sin(T))^2]
T=0*pi/180;
A43=[(cos(T))^2 cos(T)*sin(T) -(cos(T))^2 -cos(T)*sin(T); cos(T)*sin(T) (sin(T))^2 -cos(T)*sin(T) -(sin(T))^2;-(cos(T))^2 -cos(T)*sin(T) (cos(T))^2 cos(T)*sin(T);-cos(T)*sin(T) -(sin(T))^2 cos(T)*sin(T) (sin(T))^2]
T=90*pi/180;
A14=[(cos(T))^2 cos(T)*sin(T) -(cos(T))^2 -cos(T)*sin(T); cos(T)*sin(T) (sin(T))^2 -cos(T)*sin(T) -(sin(T))^2;-(cos(T))^2 -cos(T)*sin(T) (cos(T))^2 cos(T)*sin(T);-cos(T)*sin(T) -(sin(T))^2 cos(T)*sin(T) (sin(T))^2]
T=90*pi/180;
A23=[(cos(T))^2 cos(T)*sin(T) -(cos(T))^2 -cos(T)*sin(T); cos(T)*sin(T) (sin(T))^2 -cos(T)*sin(T) -(sin(T))^2;-(cos(T))^2 -cos(T)*sin(T) (cos(T))^2 cos(T)*sin(T);-cos(T)*sin(T) -(sin(T))^2 cos(T)*sin(T) (sin(T))^2]
T=53.13*pi/180;
A13=[(cos(T))^2 cos(T)*sin(T) -(cos(T))^2 -cos(T)*sin(T); cos(T)*sin(T) (sin(T))^2 -cos(T)*sin(T) -(sin(T))^2;-(cos(T))^2 -cos(T)*sin(T) (cos(T))^2 cos(T)*sin(T);-cos(T)*sin(T) -(sin(T))^2 cos(T)*sin(T) (sin(T))^2]
A=[zeros(8,8)]
syms EI
A12=EI.*A12./3
A43=EI.*A43./3
A14=EI.*A14./4
A23=EI.*A23./4
A13=EI.*A13./5
c=1
s=0
for i=[1 2 3 4]
for j=[1 2 3 4]
s=s+1
A(i,j)=A12(c,s)
end
c=c+1
s=0
end
c=1
s=0
for i=[1 2 7 8]
for j=[1 2 7 8]
s=s+1
A(i,j)= A(i,j)+A14(c,s)
end
c=c+1
s=0
end
c=1
s=0
for i=[7 8 5 6]
for j=[7 8 5 6]
s=s+1
A(i,j)= A(i,j)+A43(c,s)
end
c=c+1
s=0
end
c=1
s=0
for i=[3 4 5 6]
for j=[3 4 5 6]
s=s+1
A(i,j)= A(i,j)+A23(c,s)
end
c=c+1
s=0
end
c=1
s=0
for i=[1 2 5 6]
for j=[1 2 5 6]
s=s+1
A(i,j)= A(i,j)+A13(c,s)
end
c=c+1
s=0
end
b=A(2:6,2:6)
b=inv(b)
c=[0; 0; 0; 15; -20]
d=b*c
This one works without ei?i don't know why
this is second question
clc
clear all
syms L x W w1 %% W=w2-w1
A=[ 1 0 0 0;0 -1 0 0;-3/L^2 2/L 3/L^2 1/L;
2/L^3 -1/L^2 -2/L^3 -1/L^2]
B=A'
C=[1;x;x^2;x^3]
D=w1+W*x/L
F=C*D
E=int(F,x,0,L)
M=B*E
What is EI? AFAICT (not having Matlab) syms is a symbolic toolbox command that declares a variable to the symbolic processor and gives any variables a default value of their own names if a value is not provided. Is EI a special name for something (I believe Ei is the function name for the Exponential Integral but I can't see how that would work here)?
Yes, I don't have the MATLAB symbolic toolkit either but I believe the "syms EI" is simple creating a symbolic variable with name EI.
Just to be clear SADEQ, is this the specific code that fails? When you try to assign the symbolic variable to the previously defined numeric variable A12?
syms EI
A12=EI.*A12./3
Syms EI as any variable ,YOU CAN SAY X instead or anything
thr problem become when i use it in Matrix A
the system will fail when i try to fill A12 in A for example
however A12 has been defined(already multipled by Varaible X, EI whatever)
Do you have to declare all variables (including A12) using syms if you want the symbolic processor to take note of them? I think what you've asked Matlab to do is to multiply each element of (the numerically-defined) A12 by a symbolic variable EI (which should result in each element containing being a numeric value times EI (eg, 0.5*EI if the corresponding initial value an element is 1.5)
What do you expect to see?
What do you see (including any error messages)?
Ok, so the dynamic typing handles the following commands ok. That is, it allows you to redefine the (previously) numeric variable A12 as a symbolic. It creates a symbolic variable via multiplication with an existing symbolic variable.
Code:
A=[zeros(8,8)]
syms EI
A12=EI.*A12./3
But it draws the line at this. That is, when you attempt to redefine a single entry in a (previously) numeric matrix as a symbolic (while the other entries in the matrix remain, at this time, numeric). This behavior is not all that surprising to be honest.
Code:
A(i,j)=A12(c,s)
so can i define empty matrix , allowing me to enter symbolic?if yes how?
Thank you man
Thank you man
Try converting the whole matrix from numeric to symbolic before you start assigning the individual symbolic entries.
For example, I think this should work.
Code:
A = zeros(8,8)
A = sym(A)
10K
  • · Replies 18 ·
