Attempted to access data1(:,1); index out of bounds because size(data1)=[0,0].
  • Thread starter Thread starter Engiman
    Bounds Index
The forum discussion addresses an error encountered in MATLAB when attempting to access data from a variable named data1. The error message indicates an "index out of bounds" issue due to size(data1)=[0,0], suggesting that the variable is empty. The user successfully processes 6 columns but fails with 8 columns, indicating a potential data loading or initialization issue. The community suggests reviewing the code to ensure that data1 is properly populated before accessing its elements.
  • Familiarity with MATLAB programming
  • Understanding of matrix dimensions and indexing in MATLAB
  • Knowledge of data import techniques in MATLAB
  • Experience with debugging MATLAB code
  • Review MATLAB data import functions such as readtable or load
  • Learn about MATLAB matrix initialization and preallocation techniques
  • Investigate MATLAB error handling and debugging practices
  • Explore MATLAB documentation on matrix dimensions and indexing
This discussion is beneficial for MATLAB users, data analysts, and programmers who are troubleshooting data access issues and optimizing their code for handling larger datasets.
Engiman
Hi,
I am running a code in MATLAB process 8 columns and over 500 rows of data but i get the above error.
With 6 columns, the code works well. Your help is important.
It sounds like its not understanding your data since it says the size is [0,0] when it should be [500,8]. Could you attach the code?
11K
