Find Area of Region w/ 4 Rectangles
  • Thread starter Thread starter physics=world
    Area
The discussion revolves around finding the area of a region defined by the function f(x) = 2x + 5 over the interval [0, 2] using 4 rectangles. Participants are exploring the use of left and right endpoints for approximating the area under the curve.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of summation formulas and the substitution of variables in their calculations. Questions arise regarding the definitions of variables i and n, and the appropriateness of using a general formula for this specific problem. There is also a suggestion to evaluate the function at specific endpoints for both left and right rectangles.
The discussion is active with participants questioning each other's approaches and clarifying definitions. Some guidance has been offered regarding the evaluation of the function at specific points, but there is no explicit consensus on the method to be used.
Participants note that the problem does not specify that the rectangles must have the same base, leading to different interpretations of how to approach the problem. The interval and number of rectangles are clearly defined, but there is uncertainty about the method of approximation to be applied.
physics=world
1. Use left and right endpoints and the given
number of rectangles to find two approximations of the area of
the region between the graph of the function and the x-axis over
the given interval.
f(x) = 2x + 5; [0, 2]; 4 rectangles
i = n(n+1)/2
i can find the upper/right endpoint but the left endpoint is difficult.n
Ʃ [2(2(i -1)/(n)) + 5](2/n)
i = 1
n
(2/n)Ʃ [2(2(i -1)/(n)) + 5]
i = 1
n
(2/n)Ʃ [(4(i -1)/(n)) + 5]
i = 1
n n
(2/n){(4/n)Ʃ (i -1) + Ʃ 5}
i = 1 i = 1
and then i sub the equation in for i and solve but i do not get the right answer.
btw the correct answer is 13.
physics=world said:
i = n(n+1)/2
What are i and n in the context of this question?
n
i = 1
n
i = 1
n
i = 1
n n
i = 1 i = 1
It was ok up to that point. Exactly what substitution did you make?
n is going to equal 4.
and i sub in n(n+1)/2 for i in the equation
No, it's [itex]\sum_{i=1}^n i=n(n+1)/2[/itex].
Is there a reason why you are using that general formula for this very specific problem? You are given the interval from 0 to 2 and and asked to divide it into 4 rectangles. The problem does NOT say "rectangles with the same base" but that is the simplest thing to do- each base will have length 2/4= 1/2. The endpoints of the bases of those rectangles will be 0, 1/2, 1, 3/2, and 2. For the "left endpoints", evaluate 2x+ 5 at x= 0, 1/2, 1, and 3/2. For the "right endpoints", evaluate 2x+ 5 at x= 1/2, 1, 3/2, and 2.
  • · Replies 22 ·
  • · Replies 16 ·
