Conformal Mapping - Can't Prove Analyticity
The discussion centers on the conformal mapping defined by the function w = f(z) = z + K/z. The mapping is proven to be conformal as it meets the criteria of being analytic and having a non-zero derivative, specifically df/dz = 1 - K/z², which is non-zero for finite z. Despite initial confusion regarding the Cauchy-Riemann equations, it is established that the function is indeed analytic since f'(z) exists for all z ≠ 0. The mapping is conformal on the domain excluding the points {√K, 0, -√K}.
  • Understanding of complex functions and mappings
  • Familiarity with the Cauchy-Riemann equations
  • Knowledge of derivatives in complex analysis
  • Basic concepts of conformal mappings
  • Study the properties of analytic functions in complex analysis
  • Learn about the implications of the Cauchy-Riemann equations
  • Explore examples of conformal mappings in different contexts
  • Investigate the behavior of complex functions near singularities
Students and professionals in mathematics, particularly those studying complex analysis, as well as anyone interested in the application of conformal mappings in various fields such as physics and engineering.
chill_factor
We have the conformal map w = f(z) = z + K/z.
Prove this mapping is indeed conformal.
z = x + iy
A map w = f(z) is conformal if it is analytic and df/dz is nonzero.
f(z) = u(x,y) + iv(x,y)
df/dz = 1 - Kz^-2 =/= 0 for finite z, nonzero derivative condition met.
Attempting to prove its analytic:
f(z) = z + K/z = x+iy + K/(x+iy) = x+iy + K(x-iy)/(x+iy)(x-iy) = x+iy + K(x-iy)/(x^2+y^2)
= [x + Kx/(x^2+y^2)] + i [y - Ky/(x^2+y^2)] = u(x,y) + iv(x,y)
u(x,y) = x + Kx(x^2+y^2)^-1
v(x,y) = y - Ky(x^2+y^2)^-1
du/dx = 1 - Kx(x^2+y^2)^-2 * 2x
dv/dy = 1 + Ky(x^2+y^2)^-2 * 2y
they aren't equal therefore they do not satisfy Cauchy-Riemann relations, and the function is not analytic. However I'm directly told that it MUST be analytic because it is a conformal map. Did I make a mistake or is the problem mistyped?
Never mind I made a dumb mistake, it works.
The Cauchy-Riemann equations are conditions for two functions [itex]\mathbb{R}^2 \to \mathbb{R}[/itex] to be the real and imaginary parts of a differentiable function [itex]\mathbb{C} \to \mathbb{C}[/itex]. But to prove analyticity you didn't need to show that the real and imaginary parts of [itex]f(z) = z + K/z[/itex] satisfy the Cauchy-Riemann equations, because you already knew that [itex]f'(z)[/itex] exists for all [itex]z \neq 0[/itex] and is equal to [itex]1 - K/z^2[/itex].
Also, doesn't [itex]f'(\sqrt K) = f'(-\sqrt K) = 0[/itex]? Your function is then conformal on the open set [itex]\mathbb{C} \setminus \{\sqrt K, 0, -\sqrt K\}[/itex].
  • · Replies 19 ·
  • · Replies 27 ·
