So when i see white light, is it really just seven different photons?
The discussion centers around the nature of white light and how it is perceived by the human eye, particularly focusing on the composition of white light, the behavior of photons, and the mechanisms of color detection in the eye. It includes theoretical considerations, conceptual clarifications, and some technical explanations.
  • Some participants express confusion about why the eye perceives white light as a single color rather than as a combination of separate colors, noting that white light consists of multiple photons of different wavelengths arriving simultaneously.
  • One participant explains that the eye has three types of cone cells that respond to different wavelengths, and the perception of color arises from the varying stimulation of these cells.
  • Another participant introduces the idea that photons can exist in a superposition of frequencies, suggesting that single photons could be considered "white" under certain conditions.
  • It is noted that the eye does not detect the instantaneous electric field of light but rather averages quantities like intensity and color over time.
  • Some participants clarify that a photon is associated with a single frequency and that the concept of a "white photon" is misleading, as white light is a mixture of many wavelengths.
  • One participant draws an analogy between seeing a white TV screen and the inability of the eye to separate closely spaced colors in white light.
  • There is a discussion about the relevance of a photon's wave cycle stage when it interacts with the eye, with some arguing that the cycle's position does not affect the photon's momentum or its interaction with the eye.
  • The terminology surrounding photons and their association with distinct frequencies is debated, with references to older and modern quantum mechanics terminology causing some confusion.
Participants generally express confusion and curiosity about the nature of light and color perception, with multiple competing views on the behavior of photons and the mechanisms of color detection. No consensus is reached regarding the specifics of how the eye perceives white light or the implications of photon behavior.
Participants mention limitations in understanding related to the definitions of photons, the averaging process in the eye's detection mechanism, and the complexities of color perception that may not be fully resolved in the discussion.
jaydnul
Im a little confused as to why the eye detects white light as white instead of all the separate colors that compose white light. I mean it isn't a single photon right (multiple single photons of course)? So how do the different photons converge into one color? Also, which may seem like a very ignorant question, how does the eye detect a certain wave length when the photon is in a certain stage of its wave cycle when it instantly hits the eye. Like a blue photon hits the eye, but it is only a quarter of the way through with its cylce, so it hits the eye with wavelength of a red photon.
Science news on Phys.org
White light consists of multiple colors of light all arriving at your eye at the same time. If you want to talk in terms of photons, which can make things confusing sometimes, then you would say a lot of photons of different wavelengths are entering your eye at the same time.
Light doesn't change like this. If I shine a blue light at you, you will never see red because the light itself is the wrong wavelength. Your eye has three types of Cone Cells that detect light. Each type will absorb different wavelengths of light in different amounts. One does best in the Red area of the spectrum, the 2nd is in the Green-Yellow area, and the third is in the Blue area as you can see in the following graph.
All three overlap to some degree and it is the varying amount of stimulation that each cell receives compared to other cone cells that forms the first stage of color vision.
http://en.wikipedia.org/wiki/Color_vision
http://en.wikipedia.org/wiki/Trichromat
Edit: By the way I just noticed the "Seven different photons" part of your thread title. I just want to make sure you realize that there are more than 7 colors. The visible spectrum is not divided cleanly into colors, it is a gradual shift from one to the other. Each person will see the same wavelength of light a little differently than another person. This is especially true of colorblind people. (Who don't actually see in black and white usually)
An addition about the photons: I think you can also generate states where each photon is in a superposition of frequencies (=colors) so even the single photons can be "white".
I don't know however if this is the case in your usual white light.
The case of several photons with one wavelength each has already been explained.
Another comment about the question about the time-evolution of the electric field.
Your eye does not detect the instantaneous electric field, but time-averaged quantities like intensity (=time average of E^2) and colour (which corresponds to the energy of each single photon which corresponds to the frequency).
The classical explanation is simply: The oscillaton of the e-field is too fast to detect. Thus any detector including the eye detects the averaged quantities as i said above.
Explained quantum mechanically, the electric field is only a derived quantity and should not be considered in the detection process (which is inherently quantum mechanical because in the end single photons get absorbed by single molecules). Instead, what you actually get is a state with many photons whose energy is h*f (where f corresponds to the frequency of the actual macroscopic E-field). The receptors in the eye have some transition between internal states with some energy difference e. The receptor for the color f can absorb a photon if its energy is exactly e=hf.
This explains the statement that they eye can detect frequency/photon energy/ color.
The intensity simply means that more or less photons where detected.
I think OP is talking about the 7 colours of the rainbow red-orange-yellow-green-blue-indigo-violet taught in school. They are just convenient names for some of the visible spectrum wavelengths.
A photon is only associated with one distinct frequency of light (EM radiation) so you can't have a 'white photon'. The spectrum of light that you get from the Sun (a white hot body) is continuous and 'the seven colours' were used to describe the identifiable 'bands' that we see in a rainbow. Within those bands, there is a range of frequencies (actually, light is normally described in terms of its wavelength - for historical reasons). Our colour vision is capable of detecting differences of less than 1% in colour (hence the need for at least 24bit colour accuracy in printing). We can easily distinguish between a range of spectral colours that are basically 'greenish'.
If you mix light of different wavelengths, you can produce 'colours' which are not actually part of the spectrum at all. None of the colours we see in real life are ever just one wavelength because most illuminants (sun, lightbulbs, LEDs) produce a range of wavelengths and objects we see have pigments which do not reflect just one wavelength. The only time we see true spectral colours is when we are in a darkened room and we look at the output of a spectrometer or, in rare circumstances, when we see a gas discharge lamp - but even those tend to have emit a spectrum with a number of different lines.
same reason that we see a white tv screen from our armchair, even though close-up we can see that the screen is actually full of red green and blue dots!
in other words: the eye simply isn't accurate enough to separate out the photons if they're too close together (which in an ordinary white light they certainly are) :wink:
(btw, i don't think the eye is designed to react to individual photons, i think it needs a "threshhold" number of photons before it takes any notice of them)
… how does the eye detect a certain wave length when the photon is in a certain stage of its wave cycle when it instantly hits the eye. Like a blue photon hits the eye, but it is only a quarter of the way through with its cylce, so it hits the eye with wavelength of a red photon.
how far through the cycle it is is irrelevant
a photon of a particular wavelength has a particular momentum, and that momentum is what determines how in interacts with anything (including your eye)
the momentum is the same throughout the cycle
Well, that depends. In the quite old terminolgy of qm, the theoretical single energy modes of the em field are called photons and these are of course monochromatic (and do not correspond to anything "real" which one could measure).
In modern day quantum optics, an eigenstate of the photon number operator is also called (single) photon, at least concerning the n=1 Fock state. This latter entity can be as polychromatic as you want it to be.
Of course this coinciding terminology makes things a bit difficult - as if understanding light was not already complicated enough.
Are you saying monochromatic light from a laser isn't measurable.
Laser light has a very, very narrow linewidth, but it is not infinitely small. You can measure that by measuring the first order correlation function. It is basically the Fourier transform of the power spectral density of the light field. Its decay gives the coherence time of the light which is in turn inversely proportional to the spectral width of the light field. Longer coherence times means spectrally narrower and therefore more monochromatic light.
Therefore, you need infinitely long coherence time to get perfectly monochromatic light, which is of course unphysical. But laser light is pretty much the closest to ideal monochromatic light you can get.
sophiecentaur said:
A photon is only associated with one distinct frequency of light (EM radiation) so you can't have a 'white photon'. .
A photon is a photon number eigenstate where the photon number is 1. I don't see any reason why it should simultaneously be a frequency eigenstate.
Absolutely. I would need you to help me with the idea that an n=1 Fock state could involve a photon with a 'combination' of energies (?) Is this along the lines of a non-sinusoidal wave? But a single photon doesn't define a wave so I am lost here.
Is this just muddying the waters here, my friend? Are you havin a virtual larf? :wink:
Prior to reading this post, I did not even know that the word "larf" existed and had to look it up. ;)
As a rough sketch as to why single photons can be polychromatic consider the way single photons are typically created. The easiest way lies in using some system which offers some blockade effect for an optical transition. That may include single quantum dots, nitrogen-vacancy centers in diamond or single atoms. In all of these cases, you have some states which can only be occupied by one carrier, maybe some excited state of the atom or the exciton ground state of the quantum dot. Now as the carrier goes from the excited state to the ground state, it will take some time until the carrier can be brought back to the excited state again. For this duration you can be sure that only one photon has been emitted and no other photons will follow for a certain duration, so you have a single photon. For some systems, like the mentioned NV-centers in diamond, it is possible that the excited state does not only couple to one certain ground state, but to a continuum of states, maybe via emission into the spectrally broad phonon sideband. The emitted photon will then be in a superposition of many possible emission channels at different energies and therefore be polychromatic (in the sense that it contains probability amplitudes corresponding to all of these different energies).
We're getting way off topic here. So, getting back on topic,
Yes and no.
Yes: Our rods are sensitive to individual photons.
No (part 1): Nonetheless, we will see nothing if just one lone photon activates a rod and then nothing else happens for a while. There's a lot of signal processing that happens in the eye. One of those things is noise rejection. A single photon would be indistinguishable from noise. So even with the rods, we essentially can't detect individual photons.
No (part 2): Our rods don't see color. They're monochromatic. Go out far from the city on a moonless night. Wait half an hour or so and you will be able see (barely) because there's still some ambient light from the stars. You won't see any colors. It's our cones that see colors; see post #2. Our cones need a significant photon flux before they become active. Look at a big sheet of white paper in sunlight and you'll have tens of millions of photons activating your cones every second. Reading in low lighting conditions results in thousands to tens of thousands of photons activating your cones every second.
I'd call that more an optical illusion more than accuracy. There's an incredible amount of signal processing that occurs between the individual receptors and perception in the brain. TVs and color prints in newspapers and magazines take advantage of this signal processing to produce the illusion of a color that isn't there.
As far as our perception of white is concerned, all that matters is the extent to which those three different kinds of cones are activated. A white light source, one whose spectrum truly is flat, will activate those cones in a certain way. The exact same effect can result from the right combination of red, green, and blue lights. Obviously this does not have a flat spectrum. Because we only have three kinds of sensors, this anything but white light still looks "white".
Cockney style - as in "Gor blimey officer, are you 'avin a larf? I've only been parked 'ere for five minutes.". Popular expression amongst the English nobility.
This is beginning to make some sense to me but there are some loose ends. For such a photon to be absorbed (detected) it would need to deliver all its energy into the detecting system. It would need to match the 'transmitter' characteristics and have some sort of 'spectrum' in its own right. What could its energy be? Would it be a version of hf; a kind of
h∫(F(f)df expression, giving a 'massively energetic' photon?
In your description, are you really saying that this sort of photon is in the minority (I guess you are)? These photons would not be like your regular photons which are totally anonymous - able produced by one process, possibly frequency shifted on their journey and then absorbed by a totally different process - as with light produced thermally in a star and then absorbed in a particular gas atom transition. What sort of fractional bandwidth are we talking about?
Is this any different from the familiar photoelectric emission, in which a range of photo-electron energies will result from a broad range of incident frequencies?
How much of this is, in fact, just a way of re-stating the description of a process in terms of what we could call photons and then having to bend the model to fit?
I guess this often happens in Science though, on the way to a better model.
what does it mean that a photon has a certain color.does one want to describe color as something like color of quarks?
"Colour" in quarks is just a random name, chosen by quirky, hippy researchers (no offense to any who happen to read this! ) in the same way that they chose "Strangeness".
It hasn't anything to do with the colours we see.
You are right. Sorry. I hope it is ok to post here, that I would like to continue the discussions which are a bit off topic here in a separate topic:
https://www.physicsforums.com/showthread.php?t=660085
  • · Replies 40 ·
  • · Replies 20 ·
  • · Replies 21 ·
