Closed form expression for sum of first m terms of a combinatorial number
The discussion centers on finding a closed-form expression for the sum of the first m terms of a combinatorial number, specifically expressed as sums of the form (r1 choose k) + (r2 choose k-1) + ... + (rk choose 1). The user seeks a method to compute this sum efficiently without exhaustive addition. While the existence of a closed-form expression is uncertain, the discussion suggests exploring greedy algorithms as potential solutions. The example provided illustrates the concept with k=5 and the sum equating to 36.
  • Understanding of combinatorial numbers and binomial coefficients
  • Familiarity with the concept of greedy algorithms
  • Basic knowledge of mathematical notation and summation
  • Experience with algorithmic problem-solving techniques
  • Research closed-form expressions for combinatorial sums
  • Learn about greedy algorithms in combinatorial optimization
  • Explore mathematical proofs regarding the existence of closed-form solutions
  • Investigate efficient algorithms for computing binomial coefficients
Mathematicians, computer scientists, and anyone interested in combinatorial mathematics and algorithm design will benefit from this discussion.
JTHM
Dear Physics Forums denizens,
I have a tricky problem that I hope one of you can help me with. (It's for a personal project, nothing to do with school.) I'm looking for a closed-form expression for the sum of the first through m-th terms of a combinatorial number. For those of you unfamiliar with combinatorial numbers, here's some useful reading: http://en.wikipedia.org/wiki/Combinatorial_number_system
Basically, the idea is this: for any non-negative integers k, and b, we can express the value of b as a sum of k terms of the form (r1 choose k)+(r2 choose k-1)+(r3 choose k-2)...(rk choose 1). For every t and s where t and s are non-negative integers such that t<s, it will be the case that rt>rs (this is just true by the definition of a combinatorial number).
For example, for k=5, we can express the number 36 as (7 choose 5)+(6 choose 4)+(2 choose 3)+(1 choose 2)+(0 choose 1).
Now, the sum of all five of these terms will be 36. But suppose I just want, say, the sum of the first two terms, four terms, or any arbitrary number of terms, and I don't want to exhaustively find every term and add all of them up. The question, then is this: given k, b, and m, where k is the total number of terms in the combinatorial number, b is the value of the combinatorial number, and m is the number of terms (starting with the first term) that we want to sum, what is the closed-form expression for the sum of those terms?
Admittedly, I am not certain that a closed-form expression even exists. If you can think of a reason why there might not be a closed-form expression for the above, please share it. In the eventuality that there is no closed-form expression, if you can think of a fast algorithm to find such a sum--something faster than just adding the terms individually--that would be helpful, too.
Mathematics news on Phys.org
If I correctly understand your problem and the wiki page which says in the second or third paragraph
"Indeed a greedy algorithm finds the k-combination corresponding to N: take ck maximal with (ck,k)<=n, then take ck − 1 maximal with (ck-1,k-1), and so forth."
(with my apologies for mashing the notation into ascii)
When a mathematician is reduced to writing the word "algorithm" I always assume that means there is no known explicit equation giving the result.
If you can find a closed form solution giving the first term or, even better, giving the first n of k terms then there might be a chance that this could be used to find the closed form for the sum of those terms.
But personally I wouldn't hold out much hope.
