What is the representative fractal equation for a power law distribution?
  • Context: Graduate
  • Thread starter Thread starter nukapprentice
    Distributions Fractal
The discussion revolves around the concept of fractal distributions and their representation through equations, particularly in the context of power law distributions. Participants explore the relationship between probability density functions (PDFs) and fractal behavior, questioning how to derive a representative fractal equation from observed data, such as coastline measurements or time intervals between events.
  • Some participants propose that a linear regression of log(N) vs. log(x) can yield insights into fractal dimensions, but question how this relates to deriving a fractal equation.
  • Others argue that while linear regression produces a linear equation, the graph of a linear equation is not inherently fractal.
  • One participant clarifies that N represents the probability density function and x represents data such as the distribution of line lengths on a coastline.
  • Another participant raises questions about the nature of the data and its relationship to the probability density function, seeking clarification on what is meant by "the data."
  • There is a discussion about the existence of mean values in power law distributions, with some stating that while a mean may exist, fractal distributions do not converge on a mean value.
  • Participants express uncertainty about the terminology used, particularly regarding the definition of "representative fractal equation" and its implications.
Participants do not reach a consensus on the definitions and relationships between fractals, power law distributions, and probability density functions. Multiple competing views remain regarding the nature of the data and the implications of fractal behavior.
There are limitations in the discussion regarding the definitions of key terms such as "data," "probability density function," and "representative fractal equation." The relationship between ruler length and coastline length is also noted as a point of contention.
nukapprentice
Hello, I had a question about data which is represented by a fractal distribution. I know that the linear regression lies in the plot of log(N) vs. log(x) for which the ratio represents the fractal dimension as the limit of x going to infinity. However, how would one get the representative fractal equation of such behavior? I am very interested since fractal equations are well known to be continuous everywhere but nowhere differentiable.
nukapprentice said:
I know that the linear regression lies in the plot of log(N) vs. log(x) for which the ratio represents the fractal dimension as the limit of x going to infinity. However, how would one get the representative fractal equation of such behavior?.
A linear regression produces a linear equation and the graph of a linear equation is not a fractal.
Suppose we have some fractal object, say a coastline of an island and we define P(x) to be the perimeter of the island as measured by adding up measurements taken with a ruler of length x. Its an interesting question whether the graph of P(x) is itself a fractal. I don't know enough about fractals to say yes or no. The coastline itself and the graph of P(x) are two different things.
At any rate, you need to clarify your question. Explain what x and N are, and explain what "regression" you are asking about.
Actually what I meant was if you plot the graph log(N) vs. log(x) where N is the probability density function and x is the data, such as the amount of long lines vs. small lines on a coastline you should get a straight line. If you take the slope of log(N) vs. log(x) you do in fact get a straight line, hence why I said linear regression. If one does get such an equation, I have read that it should be represented by a fractal equation such that it is everywhere continuous, but nowhere differentiable. I guess my question is, if you do find this sort of relationship, which is represented by a power law distribution, (such as in the case of fractals), how would one get the equation which represents the behavior of the system? I hope this clears it up.
nukapprentice said:
where N is the probability density function and x is the data.
What probability density function are you talking about? And what is "the data"?
Is "the data" a random sample from "the probability function"?
The data, as stated above, is the amount of long lines vs. short lines on a coastline (to use your example from before). You could also use data such as the times between episodes of the onset of rapid heart rate measured in patients (with a random sampling of people). Here there is no single average time that characterizes the times between these events. Most often the time between episodes is brief. Less often the time is longer. The PDF has a power law form that is a straight line on a plot of Log[PDF(t)] versus Log(t). That is the thing with fractal behavior, there is usually a large number of small samples, and smaller number of large samples.
Are you saying that the mean value of a power law distribution does not exist?
Are you saying that he graph of a power law probability density is a fractal?
Fractals need not involve probability density functions or samples from them. You should explain what fractal you are talking about and what random variable you are talking about.
The relation of ruler length to coastline length usually discussed in books on fractals is that if you use a particular ruler length, then that ruler measures a particular coastline length. It doesn't give you a "randomly selected" coastline length.
no, a mean value may exist for a power law distribution, however, for a fractal distribution, the data never converges on a mean value. Also, fractals obey a power law distribution, but not all power law distributions are fractal in nature.
For the context of my question the pdf's I am talking about do involve fractals. I guess what I was stating about the coastline analogy is that when you add up all the distances of the minicurves, you will end up with an infinite length. This is where the fractional dimension comes in with fractals since the curve described with this phenomenon has infinite length although it would normally be a 1-d object in this instance.
You haven't explained what "the data" is.
If you want to talk about the pdf of a random variable, explain what random variable you're talking about.
I think you are using technical terms carelessly. And is "representative fractal equation" terminology that you have invented? What is its definition?
  • · Replies 61 ·
11K
