Physics Forums
Physics Forums (http://www.physicsforums.com/index.php)
-   Classical Physics (http://www.physicsforums.com/forumdisplay.php?f=61)
-   -   Basic fluid dynamics (http://www.physicsforums.com/showthread.php?t=667600)
bootsnbraces Jan28-13 02:07 PM
basic fluid dynamics
Hi guys and girls,
I hope you can help an electronics engineer out of his place in the mechanical world:uhh:
My very basic question is for a vessel holding a liquid at a given pressure and a given opening in the vessel how can i calculate exit velocity and mass flow rate? Like if i blow a balloon up to say 1 bar (good balloon huh:)) and then put a 1mm hole inside it how fast will the air be travelling as it leaves the balloon?
I dont need anything to detailed ( not worried about internal friction losses etc) and for now i can assume the vessel is fed by constant pressure mechanism i.e it wont drop pressure as it empties!
Any help gratefully recieved
jbriggs444 Jan28-13 03:20 PM
Re: basic fluid dynamics
Ignoring friction, the exit velocity should be just enough to squirt a stream back up to the height of the surface of the fluid.
That's about 30 feet for water at one atmosphere. 30 feet at one g is about 45 feet per second. Double the pressure and you multiply the stream velocity by sqrt(2).
Powered by vBulletin Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
© 2014 Physics Forums
