Which is more prospective engineering or physics?
  • Context: Engineering
  • Thread starter Thread starter akdude1
    Engineering Physics
The discussion centers on the comparative prospects of pursuing a career in engineering versus physics, particularly in relation to job market growth and employability after graduation. Participants explore various factors influencing career choices, including degree specialization and personal interests.
  • One participant questions the relevance of current job market growth when choosing a career path, suggesting that future employment prospects should be considered instead.
  • Another participant argues that an engineering degree may offer better employment chances due to its marketability and the familiarity of hiring managers with engineering roles.
  • It is noted that specialized degrees may be more advantageous than general ones, with engineering degrees being more vocation-oriented compared to physics degrees.
  • Some participants suggest that a double major or a combination of physics and engineering could be beneficial, particularly for those interested in experimental physics.
  • One viewpoint emphasizes the importance of pursuing a field that inspires the individual, suggesting that passion may lead to better opportunities regardless of the chosen path.
Participants express differing opinions on the marketability of physics versus engineering degrees, with no consensus reached on which field is definitively more prospective. The discussion remains unresolved regarding the best approach to choosing a major.
Participants highlight the importance of considering personal interests and potential career paths, but there is uncertainty about how specific degrees align with job market demands and the skills required by employers.
Individuals contemplating a career in engineering or physics, students deciding on their major, and those interested in the job market dynamics of STEM fields.
akdude1
Which career is show the most growth in todays world economy. Because I want to choose now what I want to focus on.
Welcome to PF;
If you are starting your studies now or shortly, you are asking the wrong question.
What you need to do is figure out which is likely to be growing in such a way that by the time you graduate (3-5years) you are likely to be employed in the field.
Todays growth tells you nothing by itself.
It is also a bad way to pick a career path, since it leaves so much unconsidered, but that's your business right?
Asking about which degree is more marketable is a legitimate question, IMO.
I'd say your chances of employment are better with an engineering degree. When you have a physics degree, you have to market your skills to a hiring manager who may or may not be open minded. Engineers don't have to do that nearly as much -- even an HR person is familiar with what an engineer is :biggrin:.
OTOH: it depends on what else you do and what sort of field you want to enter.
Degrees do tend to label you so specialized degrees to the job tend to beat general ones. It used to be that BSc's could get management jobs for eg but now those jobs go to BBS grads.
Engineering degrees tend to be more vocation-oriented than science degrees - but an employer calling for a scientist tends not to hire an engineer.
If the plan is to get the Bachelors and leave, then it probably does not matter in terms of applying for any random job asking for a Bachelors degree... Google advertises for BSc all the time for eg. but when you go to the interview they are looking for specific skills which are not usually implicit in the degree.
It is certainly a legit question - could use refining to produce a useful answer.
So do you think either double majoring or majoring in physics and minoring in engineering because i would preferably be involved in the experimental side of whichever brach of physics i end up choosing and I heard that an engineering degree can help in experimental physics
Another path is to pick one and keep an eye on the other - you will likely be able to cross-credit if you decide to shift majors later. You can tailor your earlier papers to keep your options open but you will need advise from the schools in question.
The same goes for the double major.
To my mind, best practice is to tackle the field that lights you up the most - that you find the most inspiring. Then, if you have any talent at all, the opportunities will find you: you just have to be alert for them. This approach maximizes your chance at happiness whatever you end up doing.
Thanks that helps!
  • · Replies 18 ·
  • · Replies 27 ·
  • · Replies 19 ·
