Kinematic questions(velocity of 2 contact points)
The discussion revolves around determining the velocity of a contact point between two rods, given the angular velocity of one rod and the distance from the contact point. Participants explore the relationship between the velocities of the two rods and the geometry involved in their interaction.
  • Some participants suggest that knowing the angular velocity of the left rod and the distance from the contact point allows for determining the velocity of that contact point.
  • Others argue that the velocity of the right rod at the contact point cannot simply be the same as the left rod's contact point velocity due to the sliding nature of the right rod along the left rod.
  • A participant proposes a relationship involving angular velocities and distances, indicating that the relationship changes when the rods are parallel.
  • There is a discussion about whether the velocity vector should be based on the current geometry or at a later time, with some suggesting that the time increment (dt) is arbitrarily small.
  • One participant emphasizes the need to express the velocity of the right rod's end in terms of the angular velocities of both rods.
  • Another participant raises a question about breaking down the velocity into components along the contact point and tangential to the left rod.
Participants do not reach a consensus on the exact relationship between the velocities of the two rods at the contact point, and multiple competing views remain regarding the geometry and timing of the velocities involved.
Participants express uncertainty about the timing of the velocity calculations and the geometric relationships, indicating that assumptions about the positions and angles of the rods may affect the results.
hihiip201
in the picture below
http://tinypic.com/view.php?pic=9riq9l&s=6
if we know the angular velocity of the gear on the left, as well as their current distance from contact point, what can we say about the velocity of the right rod at the contact point at anytime t?
we know it is not just the velocity of the contact point of the left rod because the right rod can be sliding along the left rod. but how do we find its exact velocity?
http://tinypic.com/view.php?pic=9riq9l&s=6if we know the angular velocity of the gear on the left, as well as their current distance from contact point, what can we say about the velocity of the right rod at the contact point at anytime t?we know it is not just the velocity of the contact point of the left rod because the right rod can be sliding along the left rod. but how do we find its exact velocity?
If you know the angular velocity of the left rod and the distance of the contact point from the centre of the left gear (rl), you can determine the velocity of the contact point (ie. in terms of ωl and rl). You then just have to relate that to the velocity of the contact point on the right rod. That relationship changes at the point where the two rods are parallel (contact point is the whole rod). So you would have to break it down into two parts (ie. one where the end of the right rod contacts the left and the other where the end of the left rod contacts the right).
AM
AM
how exactly do we relate the velocity of the contact point of left rod and right rod?
we know the velocity of left rod at contact point, but certainly right rod's velocity at the contact point wouldn't be the same since it is sliding along the left rod right?
You have to work it out from the geometry.
Consider the situation shown with the tip of the right rod is contacting the body of the left rod. You have to relate the velocity of the tip of the right rod to the velocity of the point that it is in contact with:
ωrLr = ωlrl + v where v is the speed of the end of the right rod along the length of the left rod (ie. drl/dt)/
I haven't worked it out but I think that is how you have to do it. The trick is to express v in terms of the angular velocities of the two rods.
AM
AM
my first guess is also the equation you have above, but what i have trouble is that, should vector v in your equation be based on the geometry of the two rods at current time t? or t = t +dt? to be it makes more sense to use the time at t+dt or else the left rod will end up in a awkward position.
v is just the component of the tangential velocity of the end of the right rod that is in the direction of the radius vector rl. So it is based on the angle between the two rods.
AM
AM
right but the angle between two rods at the current time? or some dt later??
if I break the velocity into two component, the component that is along the contact point of left rod , and the velocity tangential to the left rod.
After some dt later, the position of the contact point of my right rod would be a the position of the contact point of the left rod, minus some distance away from the center of the left rod.
I don't know if my question make sense, sorry about the confusion.
It does not matter. dt is arbitrarily small. If you set v(t) at t then at t+dt it will be v(t+dt) = v + dv. If you set θ(t) at t then at t+dt it will be θ(t+dt) = θ+dθ = θ+ω(dt)
What you want to find is the velocity of the contact point on the left rod. Can you express that in terms of the velocity of the end of the right rod? ie. break down the tangential velocity of the right rod ωrrr into components that are in the direction of the rl and perpendicular to that direction (ie tangential to rl).
AM
  • · Replies 17 ·
  • · Replies 60 ·
  • · Replies 17 ·
  • · Replies 49 ·
