What are the Physics of a loop-the-loop
  • Context: Undergrad
  • Thread starter Thread starter AHUGEMUSHROOM
    Physics
The discussion focuses on the physics of a vertical loop-the-loop, emphasizing the importance of centripetal acceleration in maintaining the motion of a body through the loop. The critical formula provided is a = v²/r, where 'a' represents centripetal acceleration, 'v' is velocity, and 'r' is the radius of the loop. For a roller coaster to remain on the track at the top of the loop, the centripetal acceleration must exceed gravitational acceleration. Additionally, energy conservation principles can be applied to calculate the necessary speed for safe traversal of the loop.
  • Centripetal acceleration concepts
  • Basic physics of energy conservation
  • Understanding of gravitational potential energy (mgh)
  • Mathematical manipulation of equations
  • Research centripetal acceleration calculations in detail
  • Study energy conservation in mechanical systems
  • Explore roller coaster design principles and safety measures
  • Investigate real-world applications of circular motion in engineering
This discussion is beneficial for physics students, educators, and engineers involved in mechanical design, particularly those interested in the dynamics of circular motion and roller coaster mechanics.
AHUGEMUSHROOM
What are the Physics of a "loop-the-loop"
I have to design an investigation that relates to the circular motion of a body executing a vertical "loop". Obviously, the physics involved varies quite significantly depending on the method of motion and the physical boundaries employed.
So, I was wondering if anyone one knew of some websites/links that would help with undertaking some background research before initiating the planning phase of the investigation.
Maybe check out
http://ffden-2.phys.uaf.edu/211_fall2002.web.dir/shawna_sastamoinen/Roller_Coasters.htm
The main concept you need to know is centripetal acceleration.
[itex]a=v^2/r[/itex]
The key insight is that the downward centripetal acceleration at the top of the track must exceed the gravitational acceleration for the coaster to stay on the rails. You can calculate the speed such that |a| > |g| at the top of the loop. The roller coaster ought to be moving faster than this.
You can calculate the speed by invoking energy conservation, and using the gravitational potential energy = mgh.
  • · Replies 28 ·
  • · Replies 24 ·
