Use L'Hopital's Rule to evaluate the limit
The discussion revolves around evaluating the limit of the expression (lnx)^(2/x) as x approaches infinity, specifically using L'Hopital's Rule. Participants are exploring the application of this rule in the context of limits involving logarithmic functions.
  • Participants discuss the initial attempts to apply L'Hopital's Rule and the challenges faced, including the complexity of derivatives. Questions are raised about the correct form of the function for applying the rule and how to convert it into an appropriate indeterminate form.
The conversation is ongoing, with some participants suggesting methods to transform the original expression into a suitable form for L'Hopital's Rule. There is no explicit consensus yet, but guidance has been offered regarding the necessary transformations to achieve an indeterminate form.
Participants are considering the implications of the original expression being in the form of f(x)^g(x), which leads to an indeterminate form of ∞^0. The need to convert this into a form suitable for L'Hopital's Rule is a key point of discussion.
Shay10825
Hi. Use L'Hopital's Rule to evaluate the limit.
lim x-infinity of (lnx) ^(2/x)
The answer is 1.
I kept taking the derivative but it seemed like I was going around in circles. Any help would be appreciated.
Thanks
L'Hopital's Rule does not apply to the function as written. What were your first steps?
I found the derivative of the function and it was really ugly. I don't know if it is correct.
[ [-2(lnx)^(2/x -1)][lnx*ln(lnx) -1] ]/x^2
As Diane said, you can't apply L'Hopital's rule to this function, at least not in this form.
It is possible however to alter the function so it becomes something where you can use L'Hopital. You need to convert it to an undeterminate form of 0/0 or inf/inf.
How can I convert it?
Well, what you have here is a case of f(x)^g(x) which yields the indeterminate form [itex]\infty ^0[/itex].
You can convert it to another indeterminate form by doing [itex]\exp \left( {\ln \left( {f\left( x \right)^{g\left( x \right)} } \right)} \right) = \exp \left( {g\left( x \right)\ln \left( {f\left( x \right)} \right)} \right)[/itex].
Then you have something of the form f(x)g(x) which gives a new indeterminate form [itex]\infty \cdot 0[/itex].
Finally, you can convert this to f(x)/(1/g(x)) (or the other way arround) to get either 0/0 or inf/inf so that you can use L'Hopital.
  • · Replies 23 ·
