Why Doesn't a Tennis Ball Thrown Up in a Moving Car Land Behind You?
  • Context: High School
  • Thread starter Thread starter khanites
    Physics
The discussion revolves around the physics of a tennis ball thrown vertically while sitting in a moving car. Participants explore concepts related to motion, reference frames, and the independence of vertical and horizontal motion, addressing both theoretical and practical implications.
  • One participant expresses confusion about why a tennis ball thrown up in a moving car returns to their hand instead of landing behind them, questioning the implications of motion and relativity.
  • Another participant clarifies that from the thrower's reference frame, both the ball and the person are moving at the same horizontal velocity, which explains why the ball does not land behind.
  • A different participant emphasizes the independence of vertical and horizontal motion, using the example of jumping on a moving skateboard to illustrate that both the skateboard and the jumper maintain the same horizontal velocity.
  • One participant notes that in an accelerating car, the ball would not return to the thrower's hand, suggesting that the scenario changes with different types of motion.
  • Another participant introduces the idea that real-world factors, such as wind resistance on a flatbed, could affect the ball's landing position.
  • A later reply references a common myth regarding projectile motion, suggesting that misconceptions persist due to a lack of critical examination of the physics involved.
Participants present multiple competing views regarding the effects of different conditions (e.g., constant speed vs. acceleration) on the outcome of the ball's trajectory. The discussion remains unresolved with respect to the implications of real-world factors and varying scenarios.
Some participants mention assumptions related to ideal conditions versus real-world scenarios, such as wind resistance and acceleration, which may affect the ball's motion and landing position.
khanites
Annoying Physics Question, Plz Help!
Hey guys,
I am having trouble understanding why when sitting in a car, and a tennis ball is thrown up that you do not go in front of it and why the tennis ball returns back perfectly to your hand without you having to adjust to the fact that you have moved forward and not the ball.
Now i understand that general relativity states that the laws of motion are neglible and that the laws of physics are the same regardless, but i do not understand why are.
You are moving forward yet the ball is going up, the ball should land behind you!
PLEASE HELP...
This question is bugging me BIG TIME!
ANY HELP would be appreciated.
THANKS
khanites said:
Hey guys,
You don't need relativity to understand that. The main point, I think, is your misconception that the ball is just going up. From your point of reference, yes the ball is just going up, but then you are not moving either - you are always stationary from your reference frame. From an outsider's point of view, the ball is not just moving up; it always has a horizontal velocity component same as the train's (and yours) even before it is thrown.
Hope that helps.
Wai Wong
khanites said:
Hey guys,
The vertical and horizontal components of moving objects are independent of each other. This is why when someone jumps on a moving skateboard they will land in the same spot on the skateboard. In this case, the ball (and you) are moving at the same horizontal velocity as the car. When you throw the tennis ball up while traveling in the moving car, both you and the ball have the same inital velocity (as well as horizontal velocity), only the ball has that added vertical component.
Similarly, firing a rifle bullet in a horizontal direction at some height h will strike the ground at the same time as dropping it from that height h. Or on a smaller scale, throwing a ball horizontally and dropping it from that same distance will mean that they both strike the ground at the same time.
In terms of equations of parabolic motion, Vx = Voxt (the x direction has no horizontal direction), and Vy = Voyt - gt (the y direction does have acceleration, in this case gravity). Of course the other kinematic equations for 2D motion can be found by a quick google search.
You are not just throwing the ball up, you are throwing the ball up and forward. (with respect to the ground)
THANKS for help guys.
I THINK I UNDERSTAND IT NOW!
GREAT JOB!
Thanks! Although I had nothing to do with it. I just wanted to add one perspective. If you were on a flatbed as opposed to being in a boxcar, wind resistance would definitely make the ball land behind you. For any real-world scenario, you have to factor in everything.
In an accelerating car, the ball would not return to your hand, you would move forward in relation to the ball. In a car moving at a constant speed: the car, the ball, and your hand are all moving at the same speed...
from 2006 no less...Motia
Now here is a myth that has been around for a while - and I have no idea why. The only reason that I can think of is that too many people have just taken it for granted and not really thought about it or taken a pencil to paper and see the fallacy in the idea. There are no tricks or sneaky little 'other things' - just plain down to Earth physics. "...down to earth", should be enough of a hint.
YesIam said:
from 2006 no less
A good reason to close it.
  • · Replies 60 ·
  • · Replies 20 ·
  • · Replies 45 ·
  • · Replies 22 ·
  • · Replies 49 ·
