Static pressure in ducts and vessel
The discussion focuses on calculating static pressure drops in a duct system, specifically a 10" duct venting air at 2000 CFM. A static pressure drop of 2” water column occurs for every 100 feet of duct length. To determine the pressure drop for a 1000 cubic feet airtight vessel connected to another 100 feet of 10” duct, one must sum the pressure losses from each section of the system, considering only entrance and exit losses for the tank due to its size relative to the duct diameter.
  • Understanding of static pressure and airflow dynamics
  • Familiarity with duct sizing and airflow calculations
  • Knowledge of pressure loss calculations in duct systems
  • Basic principles of fluid mechanics
  • Research "Duct pressure loss calculations" for detailed methodologies
  • Learn about "Entrance and exit losses in duct systems" for accurate assessments
  • Explore "Airflow dynamics in HVAC systems" to understand system behavior
  • Investigate "Fluid mechanics principles" to enhance foundational knowledge
Engineers, HVAC professionals, and anyone involved in designing or analyzing duct systems and pressure dynamics in air handling applications.
GordonC
If air is venting thru a 10" duct and there is a static pressure drop of
2” water column for every 100’ of length at 2000 cfm and the duct opens to a 1000 cubic feet airtight vessel and exits through another 100’ of 10” duct how can you find the pressure drop for the tank alone?
Hi Gordon. You can add up the pressure losses for each individual portion of the system to come up with a total pressure loss. The loss for the tank, assuming it's large relative to the duct diameter, is only the entrance and exit losses. There's some discussion of that here:
http://utwired.engr.utexas.edu/che354/mom/pfit.ppt
and here:
https://www.physicsforums.com/showthread.php?t=105066&page=2
  • · Replies 24 ·
  • · Replies 33 ·
13K
