PH & Concentration Help - Problem Solving
  • Thread starter Thread starter kawaiitora
    Concentration Ph
The discussion revolves around solving two problems related to pH measurement and solution preparation in a chemistry context. The first problem involves translating mV readings from a pH electrode into pH values using known buffer solutions, while the second problem concerns preparing a specific concentration of calcium and carbon in a solution.
  • Homework-related
  • One participant suggests using the Nernst equation to relate mV readings to pH values but expresses uncertainty about the best variation to use.
  • Another participant provides the Nernst equation and discusses the need to determine the number of moles of electrons transferred to balance the charge, as well as converting the natural logarithm to a base 10 logarithm.
  • For the second problem, one participant is unsure about how to start and questions whether a molecular equation is necessary.
Participants have not reached a consensus on the best approach for either problem, and multiple viewpoints and uncertainties remain regarding the methods to be used.
There are unresolved assumptions regarding the specific conditions under which the Nernst equation is applied and the details of the molecular equation for the second problem.
kawaiitora
Hi,
I need some help with a few problems. Thanks!
(1) You have a pH Electrode that reports a voltage in
mV, which is proportional to the hydrogen ion concentration
in solution. You also have pH buffers at known pH of say
4, 7 and 10. What do you do to translate the mV reading
into pH values for any given solution with pH between
4 and 10?
(2) You have DI water plus CaCl2 and NaHCO3 salts.
What do you do to prepare a solution with Ca concentration
of 10 mmol/l and total C concentration of 2 mmol/l?
Hi there kawaiitora and welcome to PF,
What are your thoughts on the problems?
Thanks for the quick reply. Sorry, I forgot about that.
(1) I'm thinking that I should use the Nernst equation, but I'm not sure which variation would be the best.
(2) For this one, I'm really not sure how to start. would I need to make up a molecular equation first?
No problem, let's take each problem in turn.
Question One
You should first start with the basic Nernst Equation;
[tex]E = E^{\theta} - \frac{RT}{nF}\cdot\ln Q[/tex]
Now, how many moles of electrons much be transferred to balance the charge on Q (which in this case is the hydrogen ion)? If we also assume standard conditions we have sorted the [itex]\frac{RT}{nF}[/itex] coefficient. Now, the next thing you should do is convert the natural log into a log to the base 10; this involves a little bit of mathematics but is petty straight forward. Next, you will want to express Q in terms of hydrogen ion concentration or activity. After which, all is plain sailing :smile:. Can you go from here?
Yep. Thanks, Hootenanny! Now, I need some help with the second problem...
  • · Replies 16 ·
