How to approx. Total pressures and Flow (CFM)
  • Thread starter Thread starter aero_ub
    Cfm Flow
The discussion focuses on approximating total pressures and airflow (CFM) in a system with two 20-foot diameter fans operating in parallel. Initially, one fan operates at 842,770 CFM with a total pressure of 0.853" wg. The conversation emphasizes the importance of fan characteristic curves obtained from manufacturers and calculating flow resistance using either Crane #410 or the Darcy Weisbach equation. The goal is to determine the new total pressure and airflow when both fans are operational, including the distribution of airflow through cooling coils versus an open hole in the unit.
  • Understanding of fan characteristic curves
  • Familiarity with Crane #410 for flow resistance calculations
  • Knowledge of the Darcy Weisbach equation
  • Basic principles of fluid dynamics and airflow measurement
  • Research how to obtain fan characteristic curves from manufacturers
  • Study the application of Crane #410 for calculating flow resistance
  • Learn the Darcy Weisbach equation and its application in airflow analysis
  • Explore methods for measuring airflow distribution in HVAC systems
Engineers, HVAC professionals, and anyone involved in designing or analyzing airflow systems in industrial or commercial settings will benefit from this discussion.
aero_ub
Here is and Example.
There is a system with 2-20ft dia. fans, in parallel, pulling air through a bunch of cooling coils with a cross-sectional area of about 800 ft^2.
One fan is running and the other is isolated by backdraft dampers. In this situation the flow through the unit is 842,770 CFM and a total pressure (static + velocity) of 0.853" wg.
If the backdraft dampers on the second fan failed and air was allowed to enter through the second 20' Dia. by 10' high fan stack into the unit...how can I approx. the new total pressure inside the unit and the resulting airflow. Also what % of that air is coming through the coils and what % is coming through the open 'hole' in the unit?
Thanks for any input
aero
Very briefly, fans have a characteristic "curve" which you can obtain from the manufacturer. You need to determine the flow resistance which you can do two ways, either by summing the resistances as given per Crane #410 or by using the Darcy Weisbach equation and determining the resistance from your known flow and pressure drop.
I'd suggest doing it both ways and see if they come out close, then trying to pin down a usable number for resistance.
Once you have the resistance, you simply put that back into the equation for flow and find the point where that flow will cross your fan curve for a single fan. I realize that's a very brief, so if you don't understand any part of that let me know and I'll clarify.
11K
