Can You Solve These Challenging Microsoft Interview Riddles?
  • Context: Undergrad
  • Thread starter Thread starter z-component
    Interview
The discussion revolves around three riddles presented in a Microsoft job interview, focusing on problem-solving strategies and reasoning. The riddles involve identifying patterns, optimizing crossing times with constraints, and timing with burning fuses. Participants explore various approaches and interpretations of the riddles without reaching definitive conclusions.
  • Riddle #1 involves identifying a pattern in a sequence, with some participants suggesting it relates to the Conway sequence.
  • For Riddle #2, various crossing strategies are proposed, with some participants suggesting a total crossing time of 17 or 18 minutes, while others argue for 19 minutes based on their interpretations of the rules.
  • Participants debate the implications of the phrase "nobody can go alone," with differing views on whether it allows for one person to return with the flashlight while another crosses.
  • Riddle #3 discusses timing 45 minutes using two fuses that burn at different rates, with one participant suggesting igniting one fuse at both ends and the other at one end.
  • Some participants express confusion over the assumptions made in the riddles, particularly regarding the number of flashlights and the crossing rules.
Participants do not reach a consensus on the solutions to the riddles, with multiple competing views and interpretations remaining throughout the discussion.
Participants highlight ambiguities in the wording of the riddles, particularly regarding the crossing rules and the necessity of the flashlight, which contribute to differing interpretations and solutions.
Individuals interested in problem-solving, logic puzzles, and interview preparation may find this discussion relevant.
  • #31
TenaliRaman said:
Err nope,
(warning : spoiler)
Assume a,b,c,d are on the left side.
Objective -> a,b,c,d to go to right side in minimum time
Constraints -> Just one flashligh, flashlight necessary to cross and bridge can balance at the max 2 people
a(1 min,flashlight),b(2 min) go right --> 2 mins
a(1 min,flashlight) goes left --> 1 mins
c(5 min,flashlight),d(10 min) go right -> 10 mins
b(2 min,flashlight) goes left --> 2 mins
Total -> 2+1+10+2+2 = 17 mins
[/Color]
-- AI
The problem is that "nobody can go alone".
Mathematics news on Phys.org
  • #32
neurocomp2003 said:
this was my solution..i'm not going to white it because its a matter of the way you interpret the question. 10min carries flashlight.5+2+1+1+1=8 = 10.
This is a good thought. When it says that they can't go alone does that mean that they have to be on the bridge the same time as someone else? If that's the case then I think that works out well.
  • #33
TenaliRaman said:
Really :confused:
Google for Conway sequence, its one of the well known sequence and according to one paper (which is not freely available unfortunately) this sequence has many interesting properties.[/Color]
-- AI
Problem #1 is actually pretty simple. Below is a clue:
How many '1's are in line #1?
  • #34
BobG said:
Tenali, you solved the problem as it should have been written. You didn't read the way it was actually written closely enough.
"You have four people at a bridge... one HAS to carry a flashlight as they cross, but only two can cross at a time. And nobody can go alone."
As written, it pretty much makes the problem unsolvable unless you either have two flashlights or get to throw the only flashlight.
Actually, with this pointed out it seems that only one person has to carry the flashlight as they (singular person) cross. So you really only need one person to carry the flashlight as they cross. The others are free to go as they please. So let 10 and 5 start out, then after 5 minutes, let 2 go, then after 2 minutes let 1 go and finish walking with 10 (unless the name of 10 is "nobody"). Total time of 10 minutes.
  • #35
AKG said:
1 3 1 1 2 2 2 1First 1 and 2 go across, then 1 comes back. Then 10 and 5 go across and then 2 comes back. Then 1 and 2 go across. Total time: 2 + 1 + 10 + 2 + 2 = 17.
"And nobody can go alone."
isn't 1 and 2 go alone when they say 'comes back'. Somehing like go back and threfore, go back alone.
  • #36
Site for Microsoft Interview Questions
http://www.emicrosoftinterview.com -Guide for Microsoft Interview Questions
  • #37
45 min ... burn both ropes at same time ..rope 1 from both ends and rope 2 from 1 end
wen rope 1 is burnout 30 min has gone ...and so out rope 2 which has 30 min left and then burn that from both ends instantaneouly affter rope 1 is ouit...even if its not instantaneous you would measure approxmatley 45 min plus 5 seconds or so
  • #38
I am resusciting this problem in a new thread, https://www.physicsforums.com/forumdisplay.php?f=33 because it deserves more discussion. To begin, that the question with 45 mins needs two strings but the same question for 15 minutes needs only one string.
michealsmith said:
45 min ... burn
  • · Replies 27 ·
  • · Replies 35 ·
10K
