Electric field in a sphere with a hole
The discussion focuses on calculating the electric field inside an insulating sphere with a spherical hole, where the sphere has a uniform charge density denoted as p. The electric field inside the sphere is defined by the equation E = p(vector(r) - vector(b))/3epsilon-naught, where vector(r) represents the position vector and vector(b) indicates the center of the sphere. The principle of superposition is employed to determine the electric field in the hole, which is confirmed to be uniform despite the presence of the hole. The participants express confusion regarding the uniformity of the electric field and the implications of multiple holes affecting the field's characteristics.
  • Understanding of Gauss's Law in electrostatics
  • Familiarity with vector calculus and vector subtraction
  • Knowledge of electric field concepts and uniform charge distributions
  • Basic principles of superposition in electric fields
  • Study the application of Gauss's Law to non-uniform charge distributions
  • Explore the concept of electric field uniformity in spherical geometries
  • Investigate the effects of multiple holes on electric field distribution
  • Learn about the mathematical treatment of electric fields using vector calculus
This discussion is beneficial for physics students, electrical engineers, and anyone studying electrostatics, particularly those interested in the behavior of electric fields in complex geometries involving charge distributions.
Sculptured
As the title implies, I am having a problem with the way this problem is done.
problem: "An insulating sphere with radius a has a uniform charge density p. The sphere is not centered at the origin but at vector(r) = vector(b). Show that the electric field inside the sphere is given by E = p(vector(r) - vector(b))/3epsilon-naught.
An insulating sphere of radius R has a spherical hole of radius a located within its volume and centered a distance b from the center of the sphere, where a < b < R (a cross section of the sphere is shown in fig 22.42). The solid part of hte sphere has a uniform volume charge density p. Find hte magnitude and direction of the E field inside the hole, and show that E is uniform over the entire hole. ( Hint: use the principle of superposition and the result of part(a)).
Alright, I have part a figured out and understand how the two vectors can be used to find the radius of the sphere by subtraction. From this I assumed it was implied that r was a vector from the origin to the outside of the sphere while b was from the origin to the center. Subtraction yields the radius. As for fig 22.42 it is a circle with radius R, charge density p, and the hole to the right with what looks to be a center on the x axis. b is the distance to it from the center and a is its radius.
Now onto finding the electric field. I know that subtracting the E field of that region from the entire field will give me the rest of the E field with the use of Gauss's law. What troubles me is in two parts. First, how is the E field in the hole uniform? I would expect the lack of the volume of the sphere to cause one side of the sphere to provide a larger E field than the other. Also, wouldn't the E field inside the hole be different at different parts? I know my teacher mentioned if you take out a second hole than the E field is not uniform. Second, how would you even define one E vector for the sphere and one for the hole if it is a large sphere made up of many particles?
first, there is more volume on one side then on the other; however, the volume on the other side is closer.
we know that there are an infinite about of vectors in this sphere, so how would you add them all up?
  • · Replies 36 ·
