Average Speed vs. Average velocity
The discussion revolves around the concepts of average speed and average velocity, particularly in the context of motion. Participants explore the definitions and differences between these two terms, as well as their implications in physics.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss whether average speed and average velocity are the same, with some asserting they are synonyms while others highlight their differences as scalar and vector quantities, respectively. Questions arise about the implications of these definitions in practical scenarios, such as when calculating instantaneous speed using distance vs. time graphs.
The discussion is active, with various interpretations being explored. Some participants provide definitions and examples to clarify the concepts, while others express confusion and seek further clarification on specific points. There is no explicit consensus on whether average speed and average velocity are usually the same.
Some participants mention their educational background, indicating that the topic is part of their current studies in physics, which may influence their understanding and the level of detail in their questions.
caprija
Do you think that average speed and average velocities are usually the same for something in motion?
Generally, they are synonyms, but velocity is usually used in the context of physics, I guess.
Ya I mean in Physics.
Are they the same? what are the differences?
I guess there's no difference, except that you usually don't use the term 'speed' in physics.
Thanks
I have one more question, to find the instantaneous speed between let's say 0 and 3 seconds using a distance vs. time graph. I first draw the line fo best fit then I would find the slope right?
It is like comparing apples and pears, they are completely different. One is a scalar the other is a vector quantity.
Actually, the average speed is the [tex]\frac{total distance travelled}{total time taken}[/tex], while average velocity is [tex]\frac{total displacement}{total time taken}[/tex]. Remember, the displacement can be zero when the distance is not.
ok so I'm confused now, when we're talking about something in MOTION is the average speed and the average velocity usually the same?
Hm, could you clarify what you meant by that?
It is possible to have an average velocity of zero, for example.
(You travel at 5 m/s for 2 sec and then you travel at -5 m/s (backwards) for 2 sec)
...and not so with speed (it is a scalar quantity).
I know, but I still don't understand the statement above. Nevermind.
I wrote:
"I do think that average speed and average velocity are usually the same for something in motion because it's still measuring time. The only diffference is that when calculating the velocity, you're calculating the rate at which the object changes it's postition."
does that sound about right?
Went offline for some time...What exactly did you not understand?
Speed is a scalar quantity. If we designate forwards as positive movement and backwards as negative movement. I can run back and forth at 1m/s and arive where I started and my speed would still be 1m/s.
Now if we are using velocity, it is a VECTOR quantity. This means that you need to indicate MAGNITUDE and DIRECTION.
If you were to run 30,000 miles forward and then 30,000 miles backwards in 3 hours, your speed would be [tex]v=\frac{60000miles}{3hours}=\frac{20000miles}{hour}[/tex]
BUT if you were to give velocity... [tex]\vec{v}=\frac{(30000miles)+(-30000miles)}{3hours}=\frac{0miles}{3hours}=\frac{0miles}{hr}[/tex]
Get it?
Notice the arrow above v to designate whether it is a scalar quantity of a vector quantity.. [tex]\vec{v}=velocity[/tex] [tex]v=speed[/tex]
Checkfate said:
...BUT if you were to give velocity... [tex]\vec{v}=\frac{(30000miles+(-30000miles)}{3hours}=\frac{0miles}{3hours}=\frac{0miles}{hr}[/tex]
Get it?
If you are so 'aware' of the difference between vector and scalar quantities, then you should be more careful when writing equalities. :biggrin:
Get it?
Yes, Thanks I get it.
But the question is really confusing, are they usually same or not?
If you're moving with a constant velocity (speed is constant, direction is constant), then the magnitude of average velocity = average speed. In such a case, the dist-time graph will always be a straight line.
In every day conversation, if someone were to ask you what velocity your ride can get you to school and back, and you're school is 200m away from your home, they are confusing speed with velocity. Let's say your car can get to school and back home in 10 minutes, well the velocity is [tex]\vec{v}=\frac{200m+(-200m)}{10min}=0m/min[/tex] This would be correct, but obviously they are asking for speed.
While in school, I would say that velocity and speed are NEVER the same past grade 10. If a question asks for the velocity, you must take vectors into account as giving the speed will be wrong! Speed is NOT velocity, even though many people whom forget about physics class assume it is :P Get it?
Even if you are traveling in a straight line in a forward direction at 10m/s, your velocity would be +10m/s while your speed is 10m/s... Small differance, but one indicates the direction, the other does not.
lol you thanks for trying.
I'm in grade 10, so this is all new to me. We're learning how to calculate average speed/velocity and instantaneous speed/velocity using secent and tangent methods.
I forget how to calculate the instantaneous velocity and speed using a graph.
Hehe, you do that through calculus :)
By "tangent methods" do you mean differentiation? Have you ever heard the term derivative? I am in grade 12 and am just learning about it now :P
But to calculate the ALMOST instantaneous speed using a graph, simply draw a secant from one point to a point fairly close and estimate the slope. I think that's about as close as you can get without using calculus.
Just remember these definitions, they are right out of my physics book.
vector : A quantity, such as velocity, completely specified by a magnitude and a direction.
scalar : A quantity, such as mass, length, or speed, that is completely specified by its magnitude and has no direction.
If you take physics 20 next year, you will learn plenty about vectors and scalars, :).
Thanks for the definitions, I wrote them down lol
i got the instantaneous speed, how would calculate the instantaneous velocity? Which points do you use?
The question asks "What is the instantaneous velocity between 0 and 3 seconds?"
To get the speed I i used rise/run (line of best fit) got 2/3 = 0.7 km/min
which points do i use to find the instantaneous velocity?
I have not yet seen a vector where the orientation was declared. But anyways.
What's the difference between [tex]\vec{v}[/tex] and [tex]-\vec{v}[/tex]? :smile:
[tex]2v[/tex] :P
caprija, about your question :) "What is the instantaneous velocity between 0 and 3 seconds?"
It sounds like the question is asking you for the average velocity between 0-3s. So your approach is right, you would take two points that lie on the on the line of best fit between x=0 and x=3 and then calculate the slope of that line. :) If you want to show your teacher that you understand it is a velocity (vector) then put [tex]\vec{v}=+0.7km/min[/tex] :)
Is the portion of the graph between 0-3s a straight line?
Checkfate said:
...If you want to show your teacher that you understand it is a velocity (vector) then put [tex]\vec{v}=+0.7km/min[/tex] :)
This would definitely be a way of showing your teacher that you don't understand anything. :smile: Since when do vector quantities equal scalar quantities? You can talk about the magnitude of the velocity vector, but then you have to write [tex]\left|\vec{v}\right|=0.7 km/min[/tex].
radou said:
Whoa, slow down just a little bit. :smile: A vector is completely specified by: magnitude ; direction ; orientation.
http://csep10.phys.utk.edu/astr161/lect/history/velocity.html"
Case closed.
"Direction" and "orientation" mean the same thing in this context. The page that you refer to says:
It is also common to indicate a vector by drawing an arrow whose length is proportional to the magnitude of the vector, and whose direction specifies the orientation of the vector.
(I added the boldface for emphasis.)
Radou, I suppose you are correct on that one. To find the velocity you would need a displacement vs time graph, not a distance vs time graph. You do not have enough information on the graph to calculate velocity. My bad.
The reason, caprija, is because you are provided with a graph with the speed of the object, but not the direction, so it is not possible to come up with a velocity unless you use the method that radou mentioned. Sorry, I misunderstood for a second there.
