What Techniques Create Ultra Pure H2O?
  • Thread starter Thread starter katchum
    Pure
The discussion revolves around techniques for producing ultra pure water (H2O), exploring various methods and their effectiveness. Participants share insights on chemical processes, laboratory practices, and potential research topics related to ultra pure water production and its challenges.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants mention reverse osmosis (RO) as a method but note it does not achieve ultra pure water levels, suggesting it typically produces water around 1 megaohm-cm.
  • One participant describes a laboratory setup that combines a charcoal filter, RO chamber, and deionization (DI) column to achieve about 10 megaohm-cm water, indicating that the theoretical limit is around 18 megaohm-cm.
  • A suggestion is made for using a DI unit to reach closer to the 18 megaohm-cm purity level.
  • Another participant proposes a multiple-stage distillation process as a potential method for achieving ultra pure water.
  • One participant expresses interest in researching the erosion of materials in ultrapure water and mentions the challenges of storage and transport of ultrapure water.
  • A brief exchange occurs regarding the effectiveness of distillation, with one participant asserting it as a solution, while another challenges its efficacy in removing chlorine from water.
Participants express differing views on the effectiveness of various methods for producing ultra pure water, with no consensus reached on the best technique. Some methods are proposed while others are contested.
Participants reference specific purity measurements (megaohm-cm) and discuss practical limitations of different methods without resolving the effectiveness of each approach. There is mention of potential gaps in existing inventories related to ultrapure water handling.
Researchers and professionals in chemistry, environmental science, and engineering may find this discussion relevant, particularly those interested in water purification techniques and related challenges.
katchum
Hi
Are there any techniques out there to make ultra pure H2O?
Reverse osmosis looks interesting, but it doesn't make ultra pure H2O.
Hello, although I do not have the answer on the chemical techniques of making pure water, cp or "chemically pure" is the grade you are looking at. Google this and manufacture processes are given for various substances.
katchum said:
Hi
Depends on how "pure" you want it...
In our lab, we make about 10 megaohm-cm water using a charcoal filter, RO chamber and a DI column. The theoretical limit is about 18 megaohm-cm, and RO water is typically about 1 megaohm-cm.
If you want close to 18 meg water, you'd best buy yourself a DI unit (Millipore, for example).
Are there any interesting doctoral topics I could research? Like problems with some kinds of instruments, problems with some components, improvements in the large scale industry?
It would seem that a multiple-stage distillation process would do the job.
I am thinking of making an inventory about all materials with all parameters like T, P, time, diameter, velocity, material to make experiments about the erosion of material in the ultrapure water.
Both stockage and transport of UPW is a problem nowadays. But I don't know if there are inventories about this already...
One Word, Distillation.
Here's another word: wrong. Try removing chlorine from water by distillation.
  • · Replies 20 ·
