Distance problem, Using Launcher need to find objects distance
  • Thread starter Thread starter crazydude032
    Launcher
The forum discussion centers on calculating the distance a projectile travels when launched at an initial velocity of 518.28 feet per second at a 45-degree angle from a height of 2.12 feet. Using the kinematic equations, the calculated distance is approximately 8392.392 feet. The discussion highlights the importance of correctly applying the equations for both the x and y axes, particularly in determining the time of flight and horizontal displacement. A suggestion is made that the initial velocity may be excessively high, potentially leading to unrealistic distance calculations.
  • Understanding of kinematic equations for projectile motion
  • Basic knowledge of trigonometry (sine and cosine functions)
  • Familiarity with gravitational acceleration (-32.15 feet/sec²)
  • Ability to solve quadratic equations
  • Research the derivation of kinematic equations for projectile motion
  • Learn how to apply trigonometric functions to resolve velocity into components
  • Explore the impact of varying initial velocities on projectile distance
  • Investigate the effects of launch angle on the range of a projectile
Engineers, physics students, and hobbyists involved in projectile motion calculations or designing launch systems will benefit from this discussion.
crazydude032
Hows it going guys, I need to now how to find distance of an object without actually shooting from my launcher. I have that it shoots 518.28 feet per sec ( initial velocity) ends at 0 ft/s (final velocity), that gravity's constant is -32.15 feet/sec2(9.8 meters/sec2), I also have that it shoots at a 45 degree angle and it launches 2.12 feet off the ground, objects weight is .0154 lbs. It feels like I have everything I need to find distance but I keep getting huge numbers. If you could solve this for me or just point me to the formulas that I would need I would greatly appreciate it:-p , This is going to help launch a projectile for a project and this formula will save me a lot of time and money
Thanx again
crazydude032 said:
...It feels like I have everything I need to find distance but I keep getting huge numbers.
...If you could solve this for me or just point me to the formulas
So, you obviously used some formula to get these huge numbers, so, present your work. :cool:
Here are the formulas
ΔX= 1/2 (initial velocity in x direction + final velocity) Δtime
vfx= vix+accelerationΔt
Δx=viΔt+ 1/2 a (Δt)^2
vf^2=vi^2+2aΔX
vf= final velocity
vi=initial velocity
a= acceleration
t=time
Δ= displacement
You must remember that in an equation vi and vf must be either along the X axis or along the Y axis.
I solved it too
Each equation can be applied to either the x or the y axis.
that means
Δx= vit+1/2at^2 is in the x direction
Δy=vit+1/2at^2 is in the y direction
Here it is solved
vi in x direction = 518.28 cos 45
vi in y direction = 518.28 sin 45
Δy=viΔt+1/2aΔt^2
-2.12= 366.48Δt-16t^2
16t^2-366.48t-2.12=0
Solve for t
t= 22.9 seconds
t in y direction = t in x direction
since acceleration = 0 in x direction
Δx=viΔt
Δx=366.48*22.9
Δx ~ 8392.392 ft
That is a long distance. If it's way of, I'm sure there is a problem with you initial velocity. 518.28 ft/s is too much.
  • · Replies 16 ·
10K
