A paradox inside Newtonian world
  • Context: Graduate
  • Thread starter Thread starter Tomaz Kristan
    Newtonian Paradox
The discussion revolves around a proposed paradox within Newtonian mechanics, specifically related to gravitational forces and the motion of masses in a system. Participants explore the implications of mass distribution, gravitational influence, and the behavior of the center of mass in this context.
  • Thomas presents a paradox involving gravitational forces and questions whether his reasoning is flawed.
  • Some participants assert that Thomas's calculations contain errors, suggesting that a thorough review is necessary to identify these mistakes.
  • One participant argues that the gravitational influence of closer, smaller masses outweighs that of more distant, larger masses, leading to a net force directed to the left.
  • Another participant emphasizes the importance of considering the net force on each mass, referencing Newton's Third Law and suggesting that the center of mass should not accelerate.
  • There is a contention regarding the behavior of the center of mass, with some suggesting it may not move left as initially proposed, while others maintain that the gravitational pull from the left will dominate.
  • Participants discuss the implications of infinite mass distributions and the potential for paradoxes arising from such scenarios, with some suggesting that the situation may be unphysical.
  • There is a proposal to analyze the system with a finite number of masses and then consider the limit as the number of masses approaches infinity.
  • Concerns are raised about the treatment of forces and the singularity at the origin, with suggestions that this may contribute to the paradox.
Participants do not reach a consensus, with multiple competing views on the validity of the paradox and the implications of gravitational forces in the described system. Disagreements persist regarding the calculations and interpretations of forces acting on the masses.
Limitations include the dependence on the assumptions about mass distribution and the treatment of infinite systems, which may not align with physical reality. The discussion remains open to interpretation and further analysis.
  • #151
Guillochon said:
So how about this: Any supposed physical situation that reduces to a conditionally convergent series is unphysical.
Something should be done. Maybe it would be enough.
For now, the construction I gave, is perfectly legal.
  • #152
An illustration of the problem. An illustration, nothing more.
The complex on the left side consists of the infinite number of ever smaller (1000 times by volume, 2 times by mass) spheres.
http://www.critticall.com/alog/Complex_of_Mass_Spheres.jpg
  • #153
Tomaz Kristan said:
There is nothing (almost nothing) to calculate. The surface reaction forces are defined to balance any negative gravitational net force.
Which part of;
[tex]L_{n} = L_{n+1} - G_{n+1} +m_{n+1} \frac{G_{n+2} + L_{n+1} -L_{n+2}}{m_{n+2}}[/tex]
is giving the trouble exactly. To me, it''s fairly straightforward that this equation says that the left reaction force on any ball depends on the left reaction forces of the two balls to the left of it. Would you care to comment.
Tomaz Kristan said:
They are not defined to balance any positive (repulsive) gravitational net force in this case. They could also be, but they are not.
You do realize that what you're saying means that whatever model you are working with, is totally unrealted to the original problem. You've introduced some external holding force on each ball, justified by nothing more than your own handwavings.
Tomaz Kristan said:
The paradox arises, if the R^3 set and the Newton's axioms are combined. Who is "to blame", I don't know.
I'm putting the balme squarely with the "lack of rigor" department.
Tomaz Kristan said:
I know, it's not a real world problem, it's just a problem of an axiomatic system, we believed it was sane.
It's a mathematical problem. So far, you've provided close to zero mathematics, Now either you're going to provide some solid mathematics that everyone can digest, or you're going to keep obstinately refusing to even put down one equation. Dodgeing the issue with handwavings or dismissing valid arguments completely smacks of crackpottery.
I'm not often this caustic, but frankly I feel at this point that you are deliberately wasting everyone's time here.
Edit:
P.S.
Please turn that bmp into a jpeg. You're causing an internet traffic jam.
  • #154
Why two? Why this equation at all? Who invented it? You?
I think, that EACH ball on the left side has its gravitational pull to a ball. All those pull forces are to be added together.
When we do that, we still have a finite force, canceled out by the surface reaction force.
Plus, a finite force from the right side is also always present, always finite.
What more do you need? The gravitational force formula? Some infinite series sums?
  • #155
I derived it in post 136!
The answers Kristan! Give your answer for the accelleration. It's the result of mathematical equations. Show your equations. The equations you presumably came up with when you first investigated these paradoxes so that you would at least have some idea what you were talking about when you presented them here rather than have the rest of us go to the trouble of coming up with just about everything for you.
Honestly!
  • #156
I can't believe this.
F(N,N+1)=G*m(N)*m(N+1)/(10^(N+1))^2=G*m(N)*(m(N)/2)/(10^(N+1))^2
For every N.
Do you agree so far?
  • #157
You can't believe what? That people would ask you to verify what you say? That people would ask you to show exactly how you arrived at the equations you use? What you've given is the gravitational force between two consecutive masses. What is the total force on each mass and what is its acceleration?
  • #158
That you don't find this arithmetic trivial.
Okay, if you want it the slow way.
Do you agree or not:
or
or
G*(m(N)^2/2)/(10^(N+1))^2
For every N.
  • #159
In the case you agree, do you agree with:
F(N,N+1)+F(N,N+2)+F(N,N+3)+ ... < 2*F(N,N+1)
Since the m(N+1)=m(N+2)+m(N+3)+m(N+4)+...
and the mass is actually distributed more away, than if it was all squeezed to the immediate left ball.
  • #160
That came out of nowhere, again without any proof whatsoever.
And...? What relevance has any of this to the accelleration of the system? You still haven't given any answers yet.
  • #161
I hate to repeat myself but what's wrong with saying that conditionally convergent series are unphysical? Doesn't this resolve the issue?
  • #162
The problem is not with the mathematics. The problem is with the axiomatic system of Newtonian mechanics, which allows (if not explicitly forbidden) a setup in which, in order to calculate the force on a body, the rule that is given by the axiomatic system LEADS TO a conditionally convergent series.
Imagine a force law which contains a term : sqrt(d - 5) where d is the distance between two points. You can now say: the fact that you get difficulties for d < 5 is related to saying that imaginary numbers are unphysical. Right. But the problem is that if the rule said that you had to apply sqrt(d - 5), and for the specific setup at hand this gives you an imaginary number (because d = 3 for instance), then that's not a problem of mathematics but of the force law at hand: it must make sure that d cannot be smaller than 5. And in the example cited here in this thread, there is no a priori reason why it should not occur (except for diverging volume mass density).
  • #163
My point is that any problem that results in a conditionally convergent series couldn't be constructed in the first place. In this case, it's because we have an infinite number of masses.
  • #164
OMF,
One of this days I'll tell you, what value exactly the sum of all left forces are. I assure you, it is smaller than if two immediate left balls were in the same place. I assure you!
A good suggestion for the future improvements, maybe. But it is not on the table now. Nor has Newton forbid this crap, not is forbidden in the R^3 set.
vanesch,
Thank you for understanding the whole picture. I like your remark, that the system might produce this kind of situation by itself, calculating or simulating something else, completely harmless at the first glance.
  • #165
Well, yes, but the total mass is finite, so this simply comes down to a special distribution of a finite mass over space. If this is not allowed, then we could not do Newtonian mechanics in continuum mechanics, where we chunk up a finite mass in an infinite number of infinitesimal amounts of mass. So it can not be this infinite chunking up which gives problems by itself.
I have my gut feeling that it is the divergent mass density which is the culprit, but there are 2 caveats:
- one should then have to be able to show that in cases where there is no such divergent mass density, that a conditionally convergent series cannot occur
- one should also (that's way trickier !) have to show that such situations cannot evolve, under Newtonian dynamics, from much more innocent mass distributions which do have finite mass densities.
(because in that way, these more innocent initial conditions should also have to be forbidden etc... and, by Poincare, we might end up by forbidding 99.9999% of all of phase space as initial condition!)
Now, as already said, this doesn't mean that there is any practical problem with Newtonian physics as an effective theory. But it is a surprise to me that it fails as an axiomatic system.
  • #166
In earlier posts I attached some mathematica notebooks calculating numerically the forces to the first problem which was posed in this thread. The results were indeed only numerical but I think it is not difficult to establish analytic inequalities.
  • #167
As a matter of fact, there is a certain possible way, to flatten those balls to pancakes. To avoid arbitrary big densities.
  • #168
OTOH, those close pancakes still cause the arbitrary high densities.
But it is conceivable, to have a force between those balls, which is proportional to r^-4. That way those balls could have even a constant density, still causing the paradox.
Anyway, something must go to arbitrary high (yet finite!) values in order to have this problem. It will remain so, until some maximal or minimal values aren't there. In the real physics we have the speed of light, Planck size and time, and so on, already.
  • #169
What axiomization of classical mechanics are you using?
  • #170
Newton's three laws of motion. The first is already a derivative, a theorem of the second, so the II. and the III.
Plus of course everything what comes with the so called real numbers.
Plus the gravity law, but this one could be replaced by some other force, behaving like that. Or even "better", to be proportional to r^-5 or something.
So, the second and the third Newton's law inside R^3 or even R.
Enough to get there, where a paradox lives.
  • #171
Plus of course everything what comes with the ... real numbers.
Newton's laws are rather informal, and certainly not complete. e.g. you've listed nothing that tells you, e.g., that a particle is something with mass and position. (which is a problem, because I don't think you can even state Newton's laws until you've postulated that particles have mass and position)
Before asking this question, I did a brief search for axiomatic Newtonian mechanics, and found Axiomatic foundations of Classical Particle Mechanics. Some key points about this paper are:
The first axiom is that there are only finitely many particles.
In theorem 3 (which deals with center of mass), they remark that the assumption of finitely many particles is essential to their formalism.
If we used their formalism, then there is no paradox: your construction is illegal.
If we took their formalism and threw out the axiom that says there are finitely many particles, then you don't have a center of mass theorem, and once again there is no paradox.
  • #172
Page 258 bottom and 259 top:
But an essential generalization of our axiom system would be obtained if we were to replace P1 by the axiom: "P is nonempty, and either finite or countably infinite." If the axiom P1 were to be liberalized in this way, however, then it would probably be desirable to add some additional axioms, as to insure that the total mass and kinetic energy of the system be finite.
  • #173
I repeat::
  • #174
No. The mass center can be very well defined for the infinite number of particles, when the mass remains finite. At least.
  • #175
The paradox does not live only with the infinite set of bodies. You may consider those left balls as glued together, and the Jupiter as the second body on the right side.
The paradox blooms fine, with "only" the infinite divisibility of the matter.
  • #176
Yes, but so is continuum mechanics then...
That's the "problem": we use Newtonian mechanics regularly with an infinite amount of "mass points".
Of course, Newtonian mechanics, limited to two mass points, and non-zero total angular momentum, is an entirely consistent axiomatic system. With one mass point also :-p
  • #177
Right; that's why that paper is an axiomatic foundation for particle mechanics, and not for continuum mechanics. :wink: I, actually, would really like to see a more general axiomatic foundation, it's just that this was all I could find.
Actually, if you use the techniques of nonstandard analysis, then these axioms are adequate. (you only need hyperfinitely many particles to approximate your continuum)
e.g. In Tomaz's original scenario NSA tells us that a particle of infinitessimal mass gets flung rightwards at transfinite speed, and that exactly makes up for the missing momentum. (That's why I was making a big deal about the behavior about the origin, because that's my best guess as to the standard analog)
  • #178
Every ball (no matter how small) has a much bigger left drag, than the right drag. It quickly escapes from the gravity of its right neighbor.
No right moving whatsoever!
  • #179
In the nonstandard model we'd use to analyze your scenario, there's a leftmost ball. :-p
  • #180
There is NO leftmost ball at all.
  • · Replies 73 ·
  • · Replies 48 ·
  • · Replies 16 ·
  • · Replies 19 ·
