Max Velocity of a Water Rocket
The maximum velocity of a PET bottle rocket can be calculated using Tsiolkovsky's equation and the relationship between pressure and exhaust velocity. Given a temperature of 30 degrees Celsius, a pressure of 1 atmosphere, an internal pressure of 40 psi, and a water volume of 300 mL, the exhaust velocity can be derived from the formula Δp = 1/2 ρ v², where ρ is the density of water. The density of water does indeed vary with temperature, which must be considered in the calculations.
  • Understanding of Tsiolkovsky's rocket equation
  • Knowledge of fluid dynamics principles
  • Familiarity with pressure units (psi to atm conversion)
  • Basic thermodynamics related to water density changes
  • Research the application of Tsiolkovsky's equation in practical scenarios
  • Study fluid dynamics principles related to exhaust velocity calculations
  • Learn about the conversion between psi and atmospheric pressure
  • Investigate how temperature affects the density of water
Aerospace engineers, physics students, hobbyists building water rockets, and anyone interested in the principles of rocketry and fluid dynamics.
flash
Find the maximum velocity of a PET bottle rocket on a day with temperature 30 degrees celsius and pressure 1 atmosphere, if the pressure inside the bottle was 40 psi and the volume of water in the bottle was 300 mL.
I know of Tsiolkovsky's equation but I'm not quite sure how to use it here. Any help appreciated :smile:
EDIT: Pretty sure I need to find the exhaust velocity of the water given the above details. I have a formula that says [tex]\Delta p = \frac{1}{2} \rho v^2[/tex] where [tex]\rho[/tex] is the density of water and p is pressure that (I think) gives the exhaust velocity v but I don't know where the formula came from or if it is even correct.
Feel free to ignore the first part of the question. I just need someone to explain that relationship between pressure and exhaust velocity there. Also I'm guessing that the density of water changes with temperature?
