How Do You Measure Thermal Conductivity and Dimensions of a Boiling Tube?
The discussion focuses on measuring the thermal conductivity and dimensions of a boiling tube, specifically in relation to pyrex glass. Participants clarify that the thermal conductivity of a boiling tube depends on the specific material and its thickness. For radius measurement, it is essential to choose either the external or internal diameter, while the thickness can be calculated by subtracting the internal diameter from the external diameter and dividing by two. Using a micrometer for direct measurement of thickness is also recommended.
  • Understanding of thermal conductivity concepts
  • Familiarity with pyrex glass properties
  • Basic geometry for calculating dimensions
  • Experience with measurement tools like micrometers
  • Research thermal conductivity values for various materials, including pyrex glass
  • Learn how to accurately measure dimensions using a micrometer
  • Explore methods for calculating thermal conductivity in experimental setups
  • Study the impact of material thickness on thermal conductivity
Researchers, materials scientists, and students conducting experiments related to thermal conductivity and dimensional analysis of glass materials.
ivylim88
Uhmm.. i faced some problem with my experiment of finding the thermal conductivity of glass..i hope that someone can help me.
May i know the extimation of the thermal conductivity of a boiling tube??
isit the same as the thermal conductivity of pyrex glass??
when i want to find the radius of the boiling tube, should i take the reading of the external diameter divided by 2 or the internal diameter divided by 2??
and about the thickness of the boiling tube, its the external diameter deduct the internal diameter then divided by 2 isit??:confused:
i will really appreciate your help..
[/QUOTE]
Not unless you specify the material and the thickness.
[/QUOTE]
I don't know since you don't say what it is.
[/QUOTE]
Which one do you think?
Yes, it is. OR ... you could just measure the thickness with a micrometer.
  • · Replies 22 ·
