Probability: mutually exclusive vs. disjoint events
Disjoint events are defined as events that have no intersection, which means they are inherently mutually exclusive. Therefore, all disjoint events are mutually exclusive, and mutually exclusive events cannot be independent. The discussion highlights that if two events are mutually exclusive, the probability of their intersection is zero, confirming they cannot occur simultaneously. For example, rolling a die cannot yield both an odd and an even number at the same time, illustrating mutual exclusivity.
  • Understanding of basic probability concepts
  • Familiarity with the definitions of disjoint and mutually exclusive events
  • Knowledge of independent events in probability theory
  • Basic skills in calculating probabilities using formulas
  • Study the concept of independent events in probability theory
  • Learn about the mathematical representation of disjoint and mutually exclusive events
  • Explore examples of probability calculations involving multiple dice
  • Investigate the implications of event independence on probability distributions
Students of probability theory, educators teaching statistics, and anyone seeking to clarify the concepts of disjoint and mutually exclusive events in probability.
VonWeber
Are all disjoint events also mutually exclusive? And if events are independent does this also mean that they cannot be disjoint?
no relevant equations
In probability disjoint events are events that have no intersection. If the events have no intersection I would think that they would have to be mutually exclusive and could not be independent either because there is no way for them to both occur at the same time.
mutually exclusive and disjoint are the same as you say the intersection is the empty set.
Two events are independent if and only if P(A intersect B)=P(A).P(B) so again you are right mutually exclusive events cannot be independent and vice versa.
Yo cannot throw a dice and get an odd number and an even number at the same time - mutually exclusive
You can throw two dice and the probability of getting two sixes is 1/36 which is the probability of getting a six on one x probability of getting a six on the other - two dice are independent of each other
P(6 & 6) =P(6).P(6)
Throwing one die
Probability of throwing an odd prime number {3,5} two out of six or 1/3
P(odd number and a prime number) =1/3
p(odd number) =1/2
p(prime number) =1/2
P(odd number and a prime number) not= p(odd number).P(prime number) so not independent events
A number being prime is independent on it being odd
Hope this helps
  • · Replies 17 ·
