How Do You Derive the Equation for Drag?
  • Thread starter Thread starter exequor
    deriving Drag
The discussion centers around deriving the equation for drag force in fluid dynamics, specifically in the context of aerodynamics. Participants are exploring the foundational concepts and mathematical relationships that lead to the drag equation.
  • Some participants attempt to recall the derivation process, mentioning the integration of pressure and shear forces over an airfoil's surface. Others express difficulty in finding resources that adequately explain the derivation, while one participant references the Buckingham Pi Theorem as a validation method.
The discussion is ongoing, with participants sharing their thoughts and resources. Some guidance has been offered regarding the integration of forces and the relevance of specific textbooks, but there is no explicit consensus on the derivation process itself.
Participants note challenges in recalling material from previous classes and the difficulty in finding comprehensive online resources. There is mention of a specific textbook that may contain relevant information, but access to it may be limited.
exequor
could someone tell me how to derive the equation for drag or send me a site that can do it.
Fd = [Coefficient of drag * density * Area (cross-sectional)*v^2 ] / 2
I can't find a site which explains it, and it's been a year since I've taken the class, so I wouldn't be able to do it justice.
Drag (and lift) are both determined first by integrating pressure and shear forces over the surface of the airfoil. Then, they are converted to the Coefficients by dividing by the dynamic pressure. That division is validated by the Buckingham Pi Theorem.
Unfortunately, every site I've found is merely an aerodynamics course syllabus which lists the topic and cites the textbook my class used (and my professor wrote FWIW... makes me happy about my education).
This is the textbook. It's expensive... I'd check to see if they've got it in the library. Everything you need is in the first chapter.
Fd(Density) = Coeficient of Drag*Density*Area∫v dv
Uh... no.
rho*A*V^2 is comes from Mach number relationships, not integrating velocity.
  • · Replies 27 ·
  • · Replies 31 ·
  • · Replies 88 ·
10K
  • · Replies 24 ·
