Differential equations - exact equations
The discussion revolves around solving an initial value problem involving an exact differential equation: 2ty^3 + 3t^2y^2 dy/dt = 0, with the condition y(1) = 1. Participants explore the steps to determine the solution and the nature of the equation.
  • The original poster attempts to verify if the equation is exact and proceeds with integration, while expressing uncertainty about isolating y(t). Some participants question the correctness of algebraic manipulations and the interpretation of constants in the integration process.
Participants are actively engaging with the problem, providing corrections and clarifications regarding the steps taken. There is a recognition of errors in algebraic reasoning, and some guidance is offered on the nature of exact equations and the implications of integrating with respect to different variables.
There are indications of potential misunderstandings regarding the definitions of functions and constants during the integration process. The discussion highlights the importance of careful algebraic manipulation in solving differential equations.
braindead101
Find the solution to the initial value problem.
2ty^3 + 3t^2y^2 dy/dt = 0 , y(1) = 1
I found out whether the equation was exact and it was, and i continued as follows. NOTE: the answer is y(t) = t^(-4/3) i just don't know how to get it. or maybe my solution is just in another form.
im going to use f instead of that greek symbol i do not how to type out here.
M(t,y) = 2ty^3
N(t,y) = 3t^2y^2
don't know why, just copied from textbook.
M(t,y) = df(t,y)/dt = 2ty^3
N(t,y) = df(t,y)/dy = 3t^2y^2
f(t,y) = integ(M(t,y)dt) + h(y)
f(t,y) = integ(2ty^3 dt) + h(y)
f(t,y) = 2y^3(1/2t^2) + h(y)
f(t,y) = y^3t^2 + h(y)
df(t,y)/dy = t^2(3y^2) + dh(y)/dy
df(t,y)/dy = 3t^2y^2 + dh(y)/dy
3t^2y^2 = 3t^2y^2 + dh(y)/dy
dh(y)/dy = 1
h(y) = integ(1 dy) + c
h(y) = y + c
f(t,y) = y^3t^2 + y + c
y^3t^2 + y = C
sub y(1) = 1
(1)^3(1)^2 + 1 = C
C= 2
.'. y(t)^3t^2 + y(t) = 2
and i can't isolate y(t) so i left that as final solution. any thoughts on whether this is right or wrong.
You've made one silly little error- and it isn't "differential equations", it's basic algebra- maybe an arithmetic error!
M(t,y) = 2ty^3
N(t,y) = 3t^2y^2
Surely your textbook defines M and N?
Your differential equation is [itex]2ty^3+ 3t^2y^2dy/dt= 0[/itex] which you can write in "differential form" as [itex](2ty^3)dt+ (3t^3y^2)dy= 0[/itex].
You want to determine whether the left side is an "exact differential"- that is, if it can be written as df for some function f(t,y). By the chain rule, [tex]df= \frac{\partial f}{\partial t}dt+ \frac{\partial f}{\partial y}dy[/tex]
So you want to know if there exist f such that
[tex]\frac{\partial f}{\partial t}= 2ty^3[/tex]
and
[tex]\frac{\partial f}{\partial t}= 3t^2y^2[/tex]
One way of determining whether such an f exists without finding it is to remember that the "mixed" derivatives are equal (as long as they are continuous). Here, if such an f exists,
[tex]\frac{\partial^2 f}{\partial y\partial t}= \frac{\partial (2ty^3}{\partial y}= 6ty^2[/tex]
and
[tex]\frac{\partial^2 f}{\partial t\partial y}= \frac{\partial (3t^2y^2}{\partial t}= 6ty^2[/tex]
Yes, those are the same so this equation is exact and such a function f(t,y) exists!
Good. In "reversing" partial integration with respect to t, in which you treat y as a constant, the "constant of integration might be a function of y- that's your "h(y)".
Strictly speaking, that should be [itex]\frac{\partial f}{\partial y}[/itex] but that's fine. The dh/dy is an "ordinary" derivative since h depends only on y.
Yes, that partial derivative must be equal to the "N(t,y)" from the equation.
dh(y)/dy = 1
What? Is that a typo? Surely, subtracting [itex]3t^2y^2[/itex] from both sides, dh/dy= 0!
h(y) = y + c
Since dh/dy= 0, h(y)= c, a constant. (And since h depends only on y, it really is a constant.)
First, it should be [itex]f(t,y)= y^3t^2+ c[/itex]. Second you don't really need the "c" here but it doesn't hurt. Since the equation is basically df= 0, f(t,y)= C and you can combine c and C- exactly as you do next.
y^3t^2 + y = C
Correction: [itex]y^3t^2= C[/itex]
sub y(1) = 1
(1)^3(1)^2 + 1 = C
C= 2
With the correction [itex](1^3)(1^2)= C[/itex] so C= 1.
[itex]y^3t^2= 1[/itex]
Well, with the correction, you can write [itex]y= ^3\sqrt{1/t^2}= t^{-\frac{2}{3}}[/itex] but you should be aware that, with first order differential equations you quite often can't solve for one variable as a function of the other. You could, for example, use "implicit differentiation" to see if the solution satisfies the differential equation: differentiating [itex]y^3t^2= 1[/itex] with respect to t, we get [itex]3y^2t^2 y'+ 2y^3t= 0[/itex]. Yes, that's exactly the original equation.
If we check you erroneous solution, [itex]y(t)^3t^2 + y(t) = 2[/itex] we get [itex]3y^2t^2y'+ 2y^3t+ y'= 0[/itex] or [itex]2y^3t+ (3y^2t^2+ 1)y'= 0[/itex] which is NOT the original equation.
By the way, in addition to being exact, this is also a "separable" equation: we can write [itex]2ty^3 + 3t^2y^2 dy/dt = 0[/itex] as [itex]3t^2y^2 dy/dt= -2ty^3[/itex] and then, dividing both sides by [itex]y^3t^2[/itex], get [itex]3dy/y= -2dt/t[/itex]. Integrating both sides, 3 ln(y)= -2ln(t)+ C so
[itex]ln(y^3)= ln(t^{-2})+ C[/itex], [itex]y^3= Ct^{-2}[/itex] and, finally, [itex]t^2y^3= C[/itex] as before.
oh wow, thanks so much
didnt correct that, so use to crossing things out and writing 1 afterwards..
i mean didnt see that mistake.. lol
i did correct it
thanks a lot.
