A paradox inside Newtonian world
  • Context: Graduate
  • Thread starter Thread starter Tomaz Kristan
    Newtonian Paradox
The discussion revolves around a proposed paradox within Newtonian mechanics, specifically related to gravitational forces and the motion of masses in a system. Participants explore the implications of mass distribution, gravitational influence, and the behavior of the center of mass in this context.
  • Thomas presents a paradox involving gravitational forces and questions whether his reasoning is flawed.
  • Some participants assert that Thomas's calculations contain errors, suggesting that a thorough review is necessary to identify these mistakes.
  • One participant argues that the gravitational influence of closer, smaller masses outweighs that of more distant, larger masses, leading to a net force directed to the left.
  • Another participant emphasizes the importance of considering the net force on each mass, referencing Newton's Third Law and suggesting that the center of mass should not accelerate.
  • There is a contention regarding the behavior of the center of mass, with some suggesting it may not move left as initially proposed, while others maintain that the gravitational pull from the left will dominate.
  • Participants discuss the implications of infinite mass distributions and the potential for paradoxes arising from such scenarios, with some suggesting that the situation may be unphysical.
  • There is a proposal to analyze the system with a finite number of masses and then consider the limit as the number of masses approaches infinity.
  • Concerns are raised about the treatment of forces and the singularity at the origin, with suggestions that this may contribute to the paradox.
Participants do not reach a consensus, with multiple competing views on the validity of the paradox and the implications of gravitational forces in the described system. Disagreements persist regarding the calculations and interpretations of forces acting on the masses.
Limitations include the dependence on the assumptions about mass distribution and the treatment of infinite systems, which may not align with physical reality. The discussion remains open to interpretation and further analysis.
  • #481
The honesty is the only tool required, as that lady said.
And a little bit of knowledge about limits also. To see that the left side force is always finite here.
  • #482
The force, to every ball, from its left side is smaller, than if it was, if all the masses on the left were concentrated at the point, where only the nearest left ball is.
This way the mass of the nearest left ball would be only doubled and the left force would be double as much, as it is now, from this nearest ball alone.
The way it is described at the post #1, it's only 992/1000 as much.
It's just trivial to see this.
  • #483
Wakalixes.
Would you mind please explaining what in my last calculation was wrong exactly?
  • #484
Where is your error?
The every next ball in the row is not ever closer. Their distancies go as 1.0d, 1.1d, 1.11d, 1.111d ... and so on.
I can't imagine, you didn't know this.
  • #485
there is also another way of approximating this, that should become more accurate as n goes to infinity.
if you merely define a desnity function that represents the distribution continuously (would the op be opposed to this?)
you can write the gravitational field as being equal to -G int[1,0] den(x) dx/x^2
which is found by finding the contribution to the total field by any infinitesimal segment of mass.
I tried doing this with the density function as e^-x (because the calculations involving this exponential function are easier) and quickly found that the integral is divergent, as you end up with ln(0) in a number of the terms, as the divergent natural log appeared due to the division by x and not the exponential I think that its safe to infer that any exponential distribution will result in a divergent gravitational field.
thus the situation is unphysical and mathematically undefinable, and so is not worth talking about.
but things like this happen quite often when working in Newtonian gravity, just try and calculate the amount of energy that a particle gains when it falls into a point mass.
  • #486
This is ridiculous. Almost "how many angels" stuff.
Tomaz, if you start with a physically imposible situation, it doesn't matter what physical model you use to evolve it, it will always remain a physically impossible situation.
My reaction to your 'paradox' - very amusing, so what ? It means nothing.
Stop wasting your time with these fantasies and study the real thing - GR cosmology.
  • #487
Luke,
I don't give any guaranties to my example changed in any way. A modification still may be no good (what's the whole intent), but I stand only behind my construction.
Here, it's not the infinite amount of energy, what is the problem. It's the rebellion against the Third Law of Newton.
The bastard between Cantor's Infinity hotel and the Newtonian mechanics is the ugly one. The paradox. No matter of good advices I get.
  • #488
My calculation considered the left force on every ball due mearly to the ball to its immediate left. If this sum is divergent, then the overall left force sum, which you yourself "proved" is "greater", is also a divergent sum. PLease read the argument again.
  • #489
This is one reason, why your calculation is wrong.
Means nothing. The sum of all forces between various parts of a rigid body can easily be divergent. So what?
  • #490
So you've been claiming for dozens of pages that the sum of all of the forces converges.
  • #491
The sum of all the forces, to every ball is finite, yes. Negative, but finite.
  • #492
And the sum of all the forces on all the balls is infinite. This has been proven twice now. Frankly, you're trolling at this point.
  • #493
The sum of all forces on all balls doesn't count. You can tile a cube to have the same "effect" of the "infinite sum of all forces".
It is not I who trolls here, OMF.
What only matters is:
Now, if that's not true, is the only question.
  • #494
To every individual ball. Look this would go a lot faster if you bothered to do some calculations.
  • #495
Calculation
The right side force to mass point m is:
(G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+...+... = (0.992*G*m*m)/(d*d)
What else do you need?
  • #496
What you have written there is what, this?:
[tex]\sum_{i=0}^{\infty} \frac{Gm^2}{2^{i+1} d^{2} \sum_{j=0}^{i} 10^{-j} }= \frac{0.922 Gm^2}{d^2}[/tex]
Im just turning your ...'s into sums.
  • #497
Looks quite good to me.
  • #498
but its not right. Left side approaches zero.
  • #499
The left side is quite weak, but I don't care. At least not more than for the OMF's calculation somewhere above.
But the right side is correct and that's enough.
  • #500
how is it correct? i was just putting what you said into calculable terms. How did you get that number, please show the math.
  • #501
I repeat myself:
>> (G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+(G*m*m/8)/(d*d*1.11*1.11)+...+... = (0.992*G*m*m)/(d*d)
It's trivial to see that.
  • #502
Even
(G*m*m/2)/(d*d)+(G*m*m/4)/(d*d*1.1*1.1)+(G*m*m/8)/(d*d*1.11*1.11)+...+... < G*m*m/(d*d)
would be quite enough. The left side force is finite. Also always exceeds the right side force.
No more is needed, no fancy math can change this strange fact. :cool:
  • #503
Tomaz Kristan said:
Am I wrong or not? What's your say?
- Thomas
Thomaz. The mathematians, physicists and engineers have answered your question. They have answered it more than fully, in many different ways, in a 34 page thread. You choose not to listen. So what do you actually want??
  • #504
Good! What was the answer?
Was it ... that a finite force is affecting every ball? All pointed to the left? At least at t=0?
:smile:
  • #505
We knew that from the very beginning. Your paradox concerns the force on the center of mass. Could you give your proof that this force is also finite.
  • #506
I don't care for the mass center. I care only for the mass particles.
I am glad that you agree with me about those.
I could, after this is settled with the majority here. That all balls are forced to the left hand side.
  • #507
Your paradox revolved around the fact that the center of mass of a closed system was supposedly moving. If your not going to aruge that anymore then there's not much else to discuss.
Well I'm settled on the finite force on every individual ball part. Care to move on to the center of mass bit?
  • #508
Fine. Everybody else also?
It can also revolves around the strange fact you admit. Only left pointed forces at t=0. A matter of choice.
  • #509
This is absolutely ridiculous. OMP has provided a considerable amount of mathematic proof that this mathematic problem is unsolvable, results a divergency. Yet, Tomaz, you still continue to provide an equation that is set up, but not your process for solving it. OMP, thus far, has constructed the only VALID argument between the two of you. And you are still unable to provide full and complete calculation of the force on the center of mass, which is where the core of this seeminly fake paradox lies.
  • #510
What is your point?
That it is all OK, if all the net forces, to every ball, are finite and left pointing, as long as the force to the mass center is divergent?
Is that your point?
  • · Replies 73 ·
  • · Replies 48 ·
  • · Replies 16 ·
  • · Replies 19 ·
