A Question to Trouble Even the Best of You
  • Context: Graduate
  • Thread starter Thread starter adityab88
    even
The discussion revolves around the search for the smallest possible arithmetic sequence consisting of seven prime numbers. Participants explore various mathematical properties, programming approaches, and theoretical implications related to prime sequences.
  • Some participants assert that there is no such sequence, while others counter that arithmetic sequences of primes exist for any finite length.
  • One participant suggests that any member of such a sequence must have the same last digit, narrowing down possibilities.
  • There is a discussion about whether this problem is more computational or mathematical in nature, with some suggesting programming knowledge is necessary.
  • A proposed sequence of primes is presented, but it is later challenged as not being an arithmetic sequence due to differing gaps between terms.
  • Another participant claims that the difference between consecutive primes must be a multiple of 30, providing an example sequence starting with 7.
  • Further exploration leads to the conclusion that the sequence must start with 7 or have spacing that is a multiple of 7, with a specific sequence of primes identified.
  • Some participants share their experiences and methods for finding sequences, with varying degrees of success and time taken.
  • There is a brief discussion about the definition of an arithmetic sequence, with a link to a mini-introduction provided by one participant.
  • A participant questions a proposed sequence of numbers, checking for primality and identifying composite numbers within it.
  • Another participant expresses a desire for resources to better understand the concepts discussed, indicating a need for clarification on modular arithmetic.
Participants express differing views on the existence and characteristics of the arithmetic sequence of seven primes. Some assert that certain sequences do not meet the criteria, while others propose potential solutions and methods. The discussion remains unresolved with multiple competing views present.
Participants reference various mathematical properties and assumptions regarding prime numbers and arithmetic sequences, but these are not universally agreed upon. The discussion includes unresolved mathematical steps and conditions that may affect the validity of proposed sequences.
adityab88
Find the smallest possible arithmetic sequence consisting of seven primes.
For example, the smallest possible arithmetic sequence consisting of five primes is: 5, 11, 17, 23, 29.
By the way, by "smallest possible" I mean that the last term in the sequence must be the smallest possible of all such sequences.
There is no such sequence.
Gib Z, you might want to think about that statement some more. It has been proven that there are arithmetic sequences of primes of any finite length.
Shhh! lol
Ill reword it then, There is no such sequence that I can be bothered to find and that has any mathematical value. To find such a sequence all one needs is some programming knowledge and to be really bored.
What can readily be established is that any member of such a sequence must have the same last digit.
So there, I have narrowed it down immensely. :smile:
Yeah, is this a computing problem or a math problem?
(Actually, it sounds more like a Google problem)
lol adityab88 you google recruit!
What type of programming do we need to solve this sort of mathematical problems? C++ ?
No idea don't ask me lol.
If you want, start a thread here inquiring about this. But not C++ I know.
Unfortunately, C++ is the only programming language I can use.
Regarding adityab88's question, here is a solution I've just gotten:
1, 11, 31, 61, 101, 151, 211, 281
And it's the smallest possible because 361 is not a prime
Rhythmer said:
Unfortunately, C++ is the only programming language I can use.Regarding adityab88's question, here is a solution I've just gotten:
However this is not an arithmetic sequence because consecutive terms do not differ by one single constant.
ie. 11-1=10, whereas 31-11=20, 61-31=30 etc..
For all terms in the sequence:
[tex]X_n = X_{n-1} + ( (n-1) * 10 )[/tex]
Starting from (n = 1), [tex]X_0 = 1[/tex]
:rolleyes:
Is my solution too bad? :frown:
:rolleyes:
The only thing wrong with it is that it is not an arithmetic sequence.
An arithmetic sequence has terms of the form: an=a0+n*d
Where a0 is the first term, and d is the common difference between terms.
hello ... ppl
i am quite sure you do not need programming equipment.
just your brains will suffice; i am sure of this because i saw this question on a maths paper, where computers were not allowedthis is all i have: the difference between the consecutive primes has to be a multiple of 30, i have shown this using some number theory. so, for example, the difference could be 60; a sequence like this (7, 67, 127, ...).
good luck and have fun!
The spacing also can't be 30:
7, 37, ..., 187 doesn't work because 187 = 11*17. But for any prime [itex]p \neq 7[/itex], we have [itex]p \equiv 2k[/itex] (mod 7) for some k, [itex]1 \leq k \leq 6[/itex]. Since 30 mod 7 = 2 that means that p+30q is divisible by 7 for some q, 1<q<=6.
That can be generalized to remove some other spacings too; I'm tired and will figure it out in the morning!
Edit: OK, I lied about figuring it out later!
You can also eliminate all other spacings, except those which are products of 7, in cases for any sequence which does not start with 7. So the sequence has to start with 7, or the spacing is a multiple of 7 (ie. 210, 420, etc.).A little bit of experimenting then yields the sequence: 7, 157, 307, 457, 607, 757, 907
Thats top stuff there Data.
good stuff
good stuff
how long did it take you to "experiment" and find the final sequence? cause i was looking for it, too, but my experimentation did not really work.
About five seconds :-p. It makes sense to start at 7; if you can find a sequence starting with 7 that has spacing smaller than 210 (and there's no smaller sequence starting with 7), then that's obviously the smallest one.
Of course, from what I've done there was no particular reason to confine myself to sequences starting with 7, so it would be fair to consider it a lucky coincidence.
What is an "arithmetical sequence"?
An arithmetic sequence is one of the form [itex](n,n+k,n+2k,n+3k,...,n+mk,...)[/itex].
Ah,yes,yes,...:smile:
To me it makes sense to start with 199 and find "minimum" prime-sequence of 10 terms with spacing 210 :
[tex] 199, 409, 619, 829, 1039, 1249, 1459, 1669, 1879, 2089[/tex].
But it took me longer time ,about 10 seconds:-p
I've written a mini-introduction to arithmetic progressions https://www.physicsforums.com/blogs/edgardo-22482/arithmetic-progressions-mini-introduction-887/
what about 31,41,51,61,71,81,91 ?
are there any non-primes in there?
but even if that is right (i doubt it is, I'm too tired to see the factors i probably should) i cheated b/c i guessed
51 and 81 are both composite.
oh
haha 9*9 = 81 yep I am tired
Any idea where i could get a description of the concepts they are talking about? (I don't want to hijack the thread)
All I used for this problem was a little bit of modular arithmetic. :smile:
  • · Replies 35 ·
12K
  • · Replies 17 ·
