Problem finding tangential acceleration
The discussion focuses on calculating tangential acceleration for a point on a rotating turntable. The problem involves a point 20.0 cm from the center accelerating from rest to 0.700 m/s in 1.75 seconds. The radial acceleration was calculated as -1.25 m/s², indicating direction towards the center, while the tangential acceleration was determined to be 0.4 m/s², derived from the formula d|v|/dt. The radial acceleration direction is always towards the center in circular motion.
  • Understanding of circular motion dynamics
  • Familiarity with acceleration concepts
  • Knowledge of basic kinematics equations
  • Ability to convert units (e.g., cm to m)
  • Study the principles of angular acceleration in circular motion
  • Learn how to apply the tangential acceleration formula in different scenarios
  • Explore the relationship between radial and tangential acceleration
  • Investigate examples of non-uniform circular motion
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators seeking to clarify concepts of acceleration in rotating systems.
Roq
Hello, I'm having problem finding tangential acceleration. I was trying to find some examples of this being done in my book and on the web, but I couldn't. So I hope someone can help me with this.
The problem is: "A point on a rotating turntable 20.0cm from the center accelerates from rest to a speed of 0.700 m/s in 1.75s. At t=1.25s, find the magnitude and direction of (a) the radial acceleration, (b) the tangential acceleration, and (c) the total acceleration of the point."
The book as only covered uniform acceleration at this point, so I assumed it was here although it did not say.
For part (a), to try and find the acceleration I did: .7m/1.75, and multiplied it by 1.25 to get the velocity at the time, getting .5 m/s. I divided -.5^2 by .2 (20 cm converted to m), getting -1.25 m/s^2. It asked for the direction, and I think the direction is given by the minus sign, indicating it is towards the center.
I am stuck on part (b). The formula for tangential acceleration is d|v|/dt, but I am unsure what formula that I have for velocity. In this case,
v = acceleration * time = 0.4m/s^2(t). So if I derived that I would get .4m/s^2. Is this the answer?
For a point in circular motion, all of the velocity is tangential. So you've already found the tangential acceleration when you found (.7 m/sec)/(1.75 sec) which gives .4 m/sec^2, and as you've assumed it's constant. You don't need that last calculation you did. It's redundant. BTW, the direction of the radial acceleration isn't really 'given by the minus sign'. You just put the minus sign in. In circular motion the radial acceleration is always 'towards the center'.
  • · Replies 35 ·
