Why is the phenomenon of increasing entropy not as straightforward as it seems?
The discussion centers on the complexities surrounding the phenomenon of increasing entropy, exploring its definitions, implications, and the relationship between energy distribution and entropy in various contexts. Participants delve into theoretical aspects, potential definitions, and philosophical implications, while also referencing concepts like "heat death" and "cold death" of the universe.
  • Some participants propose that increasing entropy can be explained by the transfer of energy from higher-energy particles to lower-energy particles during collisions, leading to a more even energy distribution.
  • Others question whether entropy can be defined solely based on energy distribution in space, suggesting that this definition may not support certain hypotheses like the "cold death" of the universe.
  • A participant discusses the relationship between entropy in statistical thermodynamics and information theory, emphasizing the need for careful terminology and the complexity of these concepts.
  • There is a mention of the mathematical definition of entropy, specifically referencing Boltzmann's entropy and its implications in different contexts.
  • Some participants express uncertainty about the conservation of energy in relation to entropy, leading to a debate about the interpretation of energy's role in systems with increasing entropy.
  • One participant suggests that the idea of "heat death" implies a homogenized universe where no free energy gradients exist, while another distinguishes between "heat death" and "cold death."
  • There is a challenge regarding the clarity of expression in discussing these complex topics, with some participants feeling that the discussion lacks straightforward answers.
Participants express differing views on the definitions and implications of entropy, with no consensus reached on several key points, including the relationship between energy conservation and entropy, and the definitions of "heat death" and "cold death." The discussion remains unresolved with multiple competing perspectives.
Participants acknowledge the complexity of the subject, indicating that a lack of background knowledge may hinder understanding. The discussion also highlights the importance of precise terminology and the potential for confusion in the literature surrounding entropy.
litewave
Can't the phenomenon of increasing entropy be explained as a result of the fact that in a collision of two particles the higher-energy particle always passes energy to the lower-energy particle (and never vice versa)? Hence energy becomes more evenly distributed in space...
Science news on Phys.org
Hmm. Can entropy be defined purely as the way energy is distributed in space ?
Yes, that's how I understand it. Via particle collisions, energy flows spontaneously from a hot (i.e. highly energetic) region to a cold (less energetic) region and as a result energy becomes evenly distributed across the two regions and the temperature of the two regions becomes equal.
The total energy passed from the hot region to the cold region is Q, the beginning temperature of the hot region is T1 and the beginning temperature of the cold region is T2. So during the energy transfer, the hot region's entropy decreases by Q/T1 (approximately, since the temperature doesn't drop instantly) and the cold region's entropy increases by Q/T2. Since T1>T2, total entropy of the system increases.
though I am not sure i don't think definition is right because it wouldn't support the "cold death" hypothesis for the universe
Some salient characteristics of "entropy"
Note that entropy is the central technical term in both statistical thermodynamics, a physical theory, and information theory, a (highly applicable!) mathematical theory allied to ergodic theory. It is essential to recognize that in both areas, many entropies are matheamtically defined and these definitions have a rather complicated mathematical relationship to one another. Thus, it is never proper to refer to "entropy" without qualification. Unfortunately, this bad habit is standard in the research literature, which is the cause of perennial and entirely unneccessary confusion
More generally, please note that IMO the intersection between information theory and statistical thermodynamics is probably the most difficult thing in modern physics, involving as it does deep philosphical, technical, and interpretive problems. So don't underestimate the importance of being very very careful in how you think and write.
Fortunately, despite some sloppiness of terminology, you appear to have hit upon some correct intuition. First, physical systems which can do useful work must have some (possibly abstract) "inhomogeneity" which can be "leveraged" (possibly in some abstract sense) to run some kind of (possibly idealized) "engine". Second, entropy does increase when one "homogenizes" a system (possibly in some abstract but deterministic sense, or possibly in a statistical sense). If you adopt a mathematical notion of entropy closely allied to the notions most often encountered, you can prove a lemma to this effect (but only valid for this particular notion of entropy).
One of the simplest mathematical definitions of "entropy" occurs in a very simple setting: partitions of a finite set (no probability measure needed, or if you prefer, we impose "counting measure"). Boltzmann suggested defining the entropy of such the partition [itex]\pi[/itex] as the log of the multinomial coefficient
[tex]S(\pi) = <br /> \log \left( <br /> \begin{array}{ccccc} & & n & & \\<br /> n_1 & n_2 & \dots & n_{r-1} & n_r<br /> \end{array} \right)<br /> = \log \, \frac{n!}{n_1! \, n_2! \dots n_{r-1}! \, n_r!}[/tex]
where the [itex]n_j[/itex] are the sizes of the r blocks of the partition, so that [itex]n = n_1 + n_2 + \dots n_r[/itex]. For convenience we can allow zero values for the [itex]n_j[/itex], as long as this sum condition holds (and [itex]n>0[/itex]).
Exercise: Assume that not all blocks have the same size. Suppose with little loss of generality that [itex]n_1 > n_2 +1 > 0[/itex]. What happens to the Boltzmann entropy if [itex]n_1 \rightarrow n_1-1, \; n_2 \rightarrow n_2+1[/itex]?
Exercise: read Weeks 247-250 and 252 (the parts dealing with Kleinian geometry) of This Weeks Finds http://www.math.ucr.edu/home/baez/TWF.html
Recalling that a Kleinian geometry arises whenever we have a group acting on a set, can you recognize a Kleinian geometry lurking behind Boltzmann's entropy?
Exercise: Try to discover and prove further formal properties of Boltzmann entropy. Can you find "categorify" these to find analogous formal properties at the level of Kleinian geometry? Are these more general?
Exercise: If you are familiar with another mathematical definition of "entropy", ditto.
Exercise: If you are not familiar with any other mathematical definitions of "entropy", apply Stirling's approximation to the Boltzmann entropy and try to find some formal properties of the quantity you come up with. What is the natural mathematical setting for its definition?
If any of this tickles your fancy, I recommend that you study one of the greatest (and most readable and most fun!) scientific papers of all time:
http://www.math.uni-hamburg.de/home/gunesch/Entropy/shannon.ps
Then read Thomas and Cover, Elements of Information Theory, Wiley, 1981. (By far the best introduction, the only one which adequately conveys some sense of the vast scope of this theory, which ranks with calculus, probability, and linear algebra, as one of the most applicable of all mathematical theories.) See http://www.math.uni-hamburg.de/home/gunesch/entropy.html for more fun on-line stuff.
A good book for anyone utterly baffled by the above is Lawrence Sklar, Space, Time, and Spacetime.
(Urgent warning!: articles on information theory and physics in the Wikipedia have been the subject of a bitter edit war between a lone dissident with very odd and inchoate but very determined views, and everyone else. No, don't ask, but I would urge anyone to strictly avoid reading Wikipedia articles on this topic until you know a great deal already, since a naive student could easily be misled and eventually have to try to "unlearn" vast amounts of misinformation. Much much better to stick with reliable sources while you are still a student!)
Chris Hillman said:
The idea of "heat death" is that the universe has been homogenized, so that no free energy gradient is possible. "Cold death" is a somewhat silly term referring to a future epoch when free energy gradients have become too diffuse to support life as we know it, or possibly (eventually) too diffuse to run any idealized information processing device. So from our perspective, they are pretty similar.
hmm so entropy obeys conservation of energy?
Chris Hillman said:
Of course not. That doesn't even make sense and I can't imagine why you thought anything I wrote would imply this.
that's exactly what your post implies, that energy is conserved but become impotent.
edit
maybe my understanding of energy is elementary, by virtue of its inability to do work it is no longer energy is what you mean.
Chris Hillman said:
Maybe you simply need to express yourself more clearly. As I already noted, this is a subtle and extremely complex subject, so clarify of expression is more important, not less so.
does the total amount of energy in the closed system of the universe remain constant?
Chris Hillman said:
It turns out that this is not an easy question to discuss, and if you don't know this, it is safe to assume that you lack the background required to try to explain why not.
Did you search for past threads on this? If you don't find anything satisfactory, why not ask about that in a new thread in the Cosmology subforum? Due to the complexity of the subject, I'd prefer that we try to keep this thread more or less on topic. TIA
no offense but telling me to rifle through other threads of abstruse information doesn't lend to my understanding. a glib answer would have sufficed.
Chris Hillman said:
Gee whiz, ice, aren't you being a little harsh? I dislike glib answers and unless I expended more time and energy than I currently have available, it's not clear that my glib answer would be better than the one offered in the WP article I cited. And please, no offense backatcha, but shouldn't you be willing to make an effort yourself?
i'm faced with a problem indemnic to people like me. i yearn to know advanced topics but to know these advanced topics i need the foundation. I'm working on a foundation, I'm a beginning physics major. for now though if i am curious about something it is pointless to try to read scholarly material because it is very opaque to me. so if i need a curiosity satisfied the best that i can hope for is a simplified answer.
though i can understand if and why you would unwilling to provide one, it is still very stultifying
Searching for an answer would have helped you out more. That is all he is trying to hint at. If you are not willing to at least look at some threads with similar issues discussed it must not be all that important.
Thanks Chris, I thought that the phenomenon of increasing entropy, or irreversible spontaneous dispersal of energy, could be explained simply from the fact that a more energetic particle always passes energy to a less energetic one, without any statistical ambiguity. Seems the matter is more complicated though
Entropy comments
If the enenrgy would be transfrerred from high-energy particle to lower ones, then the all the chemical reactions in the universe would've gone to completion, but it does not work this way. THe reaction comes to halt when the entropy generated is maximum, i.e. the products formed and the reactants left must have a high disorderness created. This is where the reaction is under equilibrium.
According to what I've read in the book, change in entropy can be negative- which means that energy can be transferred from lower energy reservoir to a higher one, this requires some work in. But the entropy generated can't be negative in real life due to the irreversibilities present, like friction.
If we consider an isloated universe (adiabatic) in which there are subsystems. Though we are not able to transfer heat to the system but even then the entropy of the universe (system) is generated due to irreversibilities present during the process going on within the system.
Final Comment: THe energy of he particles in the rxn is conserved but the entropy is generated or created during rxn, i.e. at equilibrium pt this causes the rxn to stop from proceeding furhter (or go back) w/o reacting all the high energy molecules.
I hope this helps u.
Yes, as sd_barry said, that's not really true. BTW, maximizing entropy is Legendre-dual to miniming free energy. In ancient days I used to have a post archived at my website which explained Legendre duality in two ways, one geometric and the other analytic.
Another comment on what sd_barry said: entropy in statistical mechanics is properly understood against the background of ergodic theory. The book by Lawrence Slkar, Space, Time, and Spacetime has some excellent nontechnical discussion of the Poincare recurrence theorem, which bears directly upon the Second Law.
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 17 ·
