Material Selection for VSM Tube
  • Thread starter Thread starter Fungiss
    Materials Tube
The discussion focuses on selecting materials for a temperature-varying tube used in Variable Speed Motors (VSM) that must withstand high temperatures ranging from 100 to 1100 K. Key requirements include ease of machining, suitability for medium vacuum conditions (10^-4 Torr), non-magnetic properties, and specific dimensions of 20-35 mm in diameter with a thickness of approximately 1 mm. Austenitic steels are suggested as a viable option for this application due to their favorable properties.
  • Understanding of material properties, specifically austenitic steels
  • Knowledge of machining processes for metal fabrication
  • Familiarity with vacuum technology and its requirements
  • Basic principles of thermal expansion and temperature effects on materials
  • Research the properties and applications of austenitic steels in high-temperature environments
  • Explore machining techniques suitable for non-magnetic materials
  • Investigate vacuum system design and materials compatible with medium vacuum levels
  • Study thermal management strategies for components operating at high temperatures
Engineers and designers involved in the development of components for Variable Speed Motors, materials scientists, and professionals working with high-temperature applications in vacuum environments.
Fungiss
:rolleyes:I am designing temperature varying tube for VSM, especially high temperature. I don't have any experience on materials for this component. Please give me your idea about choosing material.
Requirements for the tube is :shy::
- easy for machining
- to use for medium vacuum (10^-4 Torr).
- nonmagnetic material
- to use in temperature range of 100 - 1100 K
- diameter of 20 - 35 mm; thickness of ~ 1 mm
Thanking you! :rolleyes:
I don't know what is VSM, but austenitic steels can be helpful.
