Choosing an Initial Term for the Newton-Raphson Method: Tips and Tricks
  • Thread starter Thread starter Schrodinger's Dog
    Method
The discussion revolves around the application of the Newton-Raphson method to solve the equation x^2 - 8cos(x). Participants express concerns about selecting an appropriate initial term for the iterative method, noting that the textbook does not clarify this choice.
  • Participants discuss the nature of the initial guess, suggesting it can be an educated guess based on graphical analysis or previous computations. Some propose selecting values within a specific range, such as between 0 and 2π, and emphasize the importance of understanding the function's behavior near the root.
The conversation is active, with participants sharing their thoughts on how to choose an initial guess. Some have provided insights into the challenges of this choice, while others have shared personal experiences with their selections and outcomes. There is no explicit consensus, but several productive suggestions have emerged.
Participants note that the textbook lacks detailed explanations regarding the selection of initial terms, leading to feelings of uncertainty about the process. There is also mention of the need for understanding the function's slope and behavior to make informed guesses.
Schrodinger's Dog
Using the Newton Raphson formula to calculate a solution for
[tex]x^2-8cos(x)[/tex]
[tex]x_n+1=x_n-\frac{f(x_n)}{f'(x_n)}(n=0,1,2,3)[/tex]
I get
[tex]x_n-\frac{x^2-8cos(x)}{2x+8sin(x)}[/tex]
Fine but how do I chose an initial term [itex]x_0=?[/itex] the book does not tell me why it has chosen the initial term in its singular example, and since it appears to be random or arbitrary :rolleyes:
I think the initial guess is just that... a guess.
However, it can be an educated guess -- eg. from a previously computed value if a parameter is allowed to vary, or in your case from looking at the intersection of the graphs [tex]x^2[/tex] and [tex]8\cos(x)[/tex]
Graphs are also good to see if a solution exists!
I would just pick a number between 0 and 2[itex]\pi[/itex].
Or you could try graphing the original function, use the graph to find some approximate roots.
Newtons method is pretty robust, in can bring in a wild guess quickly.
I get
[tex]\frac{x^2-8cos(x)}{2x+8sin(x)}[/tex]
Plot y=f(x) on a graph, and pick an integer starting point near to the root. The method will then usually converge, but it doesn't always work, eg, when it crosses asymptotes etc.
Wow that was a quick answer, thanks. :smile: I don't know how your supposed to just divine that at random; sometimes I wish textbooks would actually show what they have done in detail, after all I bloody have to or they dock marks :biggrin: generally the course material is excellent but every now and again they expect you to be psychic :rolleyes:
I suppose it would logically make sense the answer would be between this range.
Ill try [itex]\pi[/itex] see what I get.
EDIT.
I used 2 and got the answer 2.0859345838069 after 5 iterations. Thanks guys, this agrees with the answer I expected :smile:
It doesn't tell because it can't -- choosing the initial point is the sore spot of Newton's method, giving rise to many other methods which precisely try to circumvent that problem.
For the Newton method to provably converge to a solution, the first derivative of the function has to be positive (or negative) and monotonically decreasing (or increasing) all the way between the initial guess and that solution.
So, one way to choose initial point is to look at the graph and pick a point from which the function "nicely" slopes down to zero.
Hm, if the function is as stated orginally, [tex]x^2 - 8\cos x[/tex], then the solution near to 2 should be about 1.343.
Chusslove Illich (Часлав Илић)
Don't worry about it I was doing a different question there, and you weren't to know that :smile: yes for the original problem I get that also.
to be honest they don't even give any pointers as you have just done ie looking for a value that slopes to zero from the graph, so your pretty much in the dark, obviously people are expected to know what they are looking for, but I didn't.
10K
  • · Replies 18 ·
