Difference between the bleaching action of SO2 and CL2
  • Thread starter Thread starter sinjan.j
    Difference
The discussion focuses on the differences between the bleaching actions of sulfur dioxide (SO2) and chlorine (Cl2), exploring their chemical properties, mechanisms, and applications in bleaching processes. Participants examine the theoretical and practical implications of using these agents in various contexts.
  • One participant suggests that the differences in bleaching action may relate to the oxidation potentials of SO2 and Cl2, as well as the identity of the resulting reduced products.
  • Another participant notes that SO2 acts as a reducing agent, producing sulfonic acid and sulfite/bisulfite ions when reacting with water, which can inhibit oxidation.
  • A later reply highlights that both bleaching agents require moisture for their bleaching action.
  • It is mentioned that chlorine bleaching relies on oxidation and nascent oxygen, while sulfur dioxide bleaching is based on reduction and nascent hydrogen.
  • Participants discuss that the bleaching effect of SO2 is temporary, whereas chlorine's bleaching action is permanent and stronger, suitable for robust materials like cotton and jute, but potentially damaging to delicate fibers.
  • SO2 is characterized as a milder bleaching agent, appropriate for more delicate fabrics such as silk and wool.
Participants express multiple competing views regarding the mechanisms and effects of SO2 and Cl2 as bleaching agents. There is no consensus on the superiority or overall effectiveness of one agent over the other, as various factors are considered.
Some limitations include the need for further clarification on the specific chemical reactions involved and the conditions under which each bleaching agent is most effective. The discussion does not resolve the complexities of the chemical processes or the implications of their use in different materials.
This discussion may be useful for individuals interested in chemistry, particularly those studying bleaching agents, their mechanisms, and applications in textile processing.
which is a better bleaching agent
  • hno3
    Votes: 1 100.0%
  • cl2
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
sinjan.j
SO2 and Cl2 are both bleaching agents. but hoe do they differ based on the bleaching action?
please help!@!
A quick guess, not necessarily the most correct guess, is that they differ by their oxidation potentials. They may also differ by identity of resulting reduced products. Sulfur compounds may or may not be advantageous or troublesome as products.
thank you for this
Actually, SO2 is a reducing agent. When it reacts with water, it produces sulfonic acid, H2SO3. The anion of this acid is sulfite and bisulfite. These are added to foods to block the action of oxidation from atmospheric oxygen.
Hint: Look up the Kraft sulfite bleaching process.
thanx for tjhis
Similarities -The one thing common between their bleaching action is both of them requires
Moisture for bleaching action.
Differences -
The bleaching action by chlorine is based on Oxidation means it requires nascent oxygen for
Bleaching action. While sulphur dioxide bleaching is based upon the reduction (Use of the
nascent hydrogen)
Another difference is the bleaching action of sulphur dioxide is temporary while bleaching
Action of chlorine is permanent.
Basically bleaching action by chlorine is strong-Used for bleaching cotton, jute,It also
Damages delicate fibres by vigorous reaction.
While SO2 is Mild bleaching agent..Used to bleach delicate fibres like silk,wool..Does not
damage fabric as its not strong.
  • · Replies 26 ·
  • · Replies 140 ·
15K
  • · Replies 18 ·
