Verifying Greens Theorem for Region R with P(x,y)=xy, Q(x,y)=x^2
The discussion revolves around verifying Green's Theorem for a specific region defined by the inequalities \(x^2 + y^2 \leq 1\), \(x + y \geq 0\), and \(x - y \geq 0\), with the vector field components \(P(x,y) = xy\) and \(Q(x,y) = x^2\).
  • Participants discuss the limits of integration for the region in polar coordinates, questioning the reasoning behind the angular limits of \(-\frac{\pi}{4}\) to \(\frac{\pi}{4}\). There is also exploration of the line integrals corresponding to the boundaries of the region, with some participants seeking clarification on the setup and evaluation of these integrals.
Some participants have provided guidance on interpreting the region and the limits of integration, while others are exploring the correctness of their computations and the implications of the direction of the line integrals. There is an ongoing examination of the results obtained from the line integrals and their relationship to the application of Green's Theorem.
Participants note the importance of accurately drawing the region defined by the inequalities and how this affects the limits of integration. There is also mention of potential mistakes in the direction of the line integrals, which may impact the final results.
smoothman
how can greens theorem be verified for the region R defined by [tex](x^2 + y^2 \leq 1), (x + y \geq 0), (x - y \geq 0) ...<br /> P(x,y) = xy, Q(x,y) = x^2[/tex]
> okay i know [tex]\int_C Pdx + Qdy = \int\int \left(\frac{dQ}{dx} - \frac{dp}{dy}\right) dA[/tex]
so: [tex]\int_C xy dx + x^2dy = \int\int_D \left(2x - x\right) dy dx[/tex]
here's my problem:
the limits of integration for the region D expressed as polar co-ordinates are:
[tex]-\frac{\pi}{4}\leq \theta \leq \frac{\pi}{4} \mbox{ and }0\leq r\leq 1[/tex]
i understand "r" is from 0 to 1 because of the radius...
but how do you explain why theta is from -pi/4 to pi/4
anyways using those limits for integration this is what i got:
ok so using polar co-ordinates:
2x - x = x
in polar terms: x = rcos\theta
so the integral is now:
[tex]\int_C xy dx + x^2dy = \int^{\pi/4}_{-\pi/4}\int^1_0 \left(rcos\theta\right)(r) drd\theta = \int^{\pi/4}_{-\pi/4}\left[\frac{1}{3}r^3cos\theta\right]^1_0d\theta = \int^{\pi/4}_{-\pi/4}\left[\frac{1}{3}cos\theta\right]d\theta = \left[\frac{1}{3}sin\theta\right]^{\pi/4}_{-\pi/4} = \frac{2}{3}sin(\pi/4)[/tex]
is my result correct?
lastly, the curl integral can be shown using three line integrals:
[tex] \bold{r}_1(t) = t\cos \frac{\pi}{4}\bold{i}-t\sin \frac{\pi}{4}\bold{j} \mbox{ for }0\leq t\leq 1[/tex]
[tex] \bold{r}_2(t) = t\cos \frac{\pi}{4}\bold{i}+t\sin \frac{\pi}{4}\bold{j} \mbox{ for }0\leq t\leq 1[/tex]
[tex] \bold{r}_3(t) = \cos t\bold{i} + \sin t \bold{j} \mbox{ for }-\frac{\pi}{4} \leq t\leq \frac{\pi}{4}[/tex]
can you please explain why the line integrals are as they are.
First draw the region given to you .
[tex](x^2 + y^2 \leq 1), (x + y \geq 0), (x - y \geq 0)[/tex]
The boundary of region is determined by the lines x=y, x=-y and the circle [tex]x^2+y^2\eq 1[/tex]
Circle gives you first limit [tex]0\leq r\leq 1[/tex]
and these two lines gives you limit for theta
(x=y and x=-y makes angle pi/4 w.r.t x-axis)
And by the inequalities you conclude theta should be between -pi/4 and pi/4
They are the curves on which you will evaluate your line integral directly
If you did draw the region correctly
you will see (it is like a slice of a pizza) r1 r2 and r3 are the linesegmentsbounding the region
To be more clear
r1 is part of x-y=0
x=rcos(theta) y=r sin(theta) and you know theta =pi/4 and r changes from 0 to 1 (you can replace r by t anyway just notation)
The others are similar
r2 is part of x+y=0
r3 is part of the circle which is an arc from -pi/4 to pi/4 with radius 1
edit:region is drawn in the picture
just checking
thanks for this one: from the information provided here is what i managed to work out:
i know [tex]\int Pdx + Qdy = \int xy dx + \int x^2 dy[/tex] since P=xy and Q=x^2
for r1(t)
so:
[tex]\int_c xy dx + \int_c x^2 dy= \int^1_0 -\frac{1}{2}t^2(sin\frac{\pi}{2})(cos\frac{\pi}{4}) dt[/tex] + [tex]\int^1_0 t^2(cos^2\frac{\pi}{4})(-sin\frac{\pi}{4}) dt[/tex]
= [tex]\int^1_0 -\frac{1}{2}t^2(cos\frac{\pi}{4}) dt[/tex] + [tex]\int^1_0 -\frac{1}{2}t^2(sin\frac{\pi}{4}) dt[/tex]
= [tex]\left[-\frac{1}{6} t^3 cos(\pi/4) \right]^1_0[/tex] + [tex]\left[-\frac{1}{6} t^3 sin(\pi/4) \right]^1_0[/tex]
= [tex]-\frac{1}{6}cos(\pi/4) + -\frac{1}{6}sin(\pi/4)[/tex]
for r2(t)
i got: [tex]\frac{1}{6}cos(\pi/4) + \frac{1}{6}sin(\pi/4)[/tex]SO THE LINE INTEGRALS OF r1(t) and r2(t) cancel each other out.
for r3(t)... This is where I am having problems
[tex]\int_c xy dx + \int_c x^2 dy = \int^\frac{\pi}{4}_\frac{-\pi}{4}-cos(t)sin^2(t) dt[/tex] + [tex]\int^\frac{\pi}{4}_\frac{-\pi}{4}cos^3(t)[/tex]
but i can't seem to do any more of it.. stuck here.. how do i complete it
ok the questions:
(a) were my line integrals of r1 and r2 correct
(b) what is the answer of r3
(c) is the final answer of these line integrals [tex]\frac{2}{3}sin(\pi/4)[/tex]
(c) We have to find [tex]\frac{2}{3}sin(\pi/4)[/tex]
Because using greens theorem you did so.
(b)[tex]\int_c xy dx + \int_c x^2 dy = \int^\frac{\pi}{4}_\frac{-\pi}{4}-cos(t)sin^2(t) +cos^3(t)dt[/tex]
It seems you have done hard part but stopped at the easy part.
Using identity[tex]cos^2^(t)+sin^2(t)=1[/tex] write
[tex]cos^3(t) = cos(t) (1-sin^2(t))[/tex] then substitude
You will find
[tex]\int^\frac{\pi}{4}_\frac{-\pi}{4}-2cos(t)sin^2(t) +cos(t)dt[/tex]
Use the substitution
[tex]u=sin(t)[/tex]
Anyway you will find at the end by substituting [tex]sin(\pi/4) = \frac{ \sqrt{2} }{2}[/tex] integral is equal to [tex]\frac{2 \sqrt{2} }{3}[/tex]
which is not an expected result for you
the reason is the answer of the question (a) is not yes
(a) You did good computations and "computationaly"
your line integrals for r1 and r2 are correct .On the other hand you did mistake in the directions(please look at the attachment) .
For r2 : t does not go from 0 to 1 , it goes from 1 to 0 .
So just multiply by -1 to revert the direction of the integral
As a result sum of the line integrals of r1 and r2 not equal to zero
Conclusion= If you add them all , you get [tex]\frac{ \sqrt{2} }{3}[/tex]
  • · Replies 105 ·
13K
  • · Replies 19 ·
