Help , liquid-liquid extracction
  • Thread starter Thread starter daysyworld
The discussion focuses on a liquid-liquid extraction problem involving two liquids, A and B, with similar boiling points, requiring the use of a solvent C. The goal is to calculate the minimum quantity of extract needed to achieve an 82% A and 17% B extract, as well as a 10% A and 90% B refined product, based on a feed composition of 35% A and 65% B. Additionally, the ideal number of extraction stages is to be determined, considering a specific reflux ratio. The feed quantity is specified as 1000 kg.
  • Understanding of liquid-liquid extraction principles
  • Knowledge of phase diagrams and solvent-free coordinate graphs
  • Familiarity with mass balance calculations in chemical engineering
  • Experience with reflux ratio calculations in separation processes
  • Study the principles of liquid-liquid extraction in chemical engineering
  • Learn how to construct and interpret phase diagrams for liquid mixtures
  • Research mass balance equations for multi-component systems
  • Explore reflux ratio calculations and their impact on separation efficiency
Chemical engineering students, process engineers, and professionals involved in separation processes and liquid-liquid extraction techniques.
daysyworld
Hello, I've been two days trying to resolve this problem and I can't.
I will try to translate it.
To liquid, A and B have very similar boiling point. Because of that would be separate by liquid-liquid extraction with a dissolvent C.
Calculate the minimum quantity of extract we have to return of the product of extract and the refined quantity to obtain a 82% A 17% B extract ( solvent free basis) and 10% A 90% B refined ( solvent free basis too).
Feed is 35% A, 65 % B ( solvent free) and it is a saturated refined.
Calculate the ideal number of stages at the both sides of feeding with the same feed to get the same final product when the reflux relation (on kg of extract with solvent) / kg of extract product is the double of the minimun value
The feed is 1000kg .
Do on equilateral triangle, rectangle triangle and solvent free coordinate graph.
Thank you very very much.
This looks like a homework problem. The forum rules are that you need to show your work before you get help. What have you attempted with this problem, and where are you stuck?
  • · Replies 16 ·
32K
  • · Replies 17 ·
9K
  • · Replies 21 ·
10K
  • · Replies 16 ·
