Why is the time interval between the events in frame S larger than in frame S'?
The discussion centers on the relativistic effects of time intervals between events in different reference frames, specifically frames S and S'. Using the Lorentz transformation equations, x=gamma*(x'+vt') and t=gamma*(t'+vx'/c^2), it is established that the time interval between two events in frame S is greater than in frame S' by a factor of gamma. The calculations demonstrate that while events occur simultaneously in S', they are not simultaneous in S, leading to a longer time interval in the latter frame.
  • Understanding of Lorentz transformations
  • Familiarity with the concept of gamma (γ) in special relativity
  • Knowledge of the speed of light (c) and its implications in physics
  • Basic grasp of reference frames in physics
  • Study the derivation of the Lorentz transformation equations
  • Explore the implications of time dilation in special relativity
  • Learn about simultaneity and its relativity in different frames
  • Investigate the concept of spacetime intervals and their significance
Students of physics, particularly those studying special relativity, educators teaching relativity concepts, and anyone interested in the mathematical foundations of time and space in physics.
Benzoate
Two events happen at the same point x'(0) in frame S' at t(1)' and t(2)'
a) Use equations x=gamma*(x'+vt') and t=gamma*(t'+vx'/c^2) to show in frame S the time interval between the events is greater than t(2)'-t(1)' by a factor of gamma
x=gamma*(x'+vt')
t(2)=gamma*(t(2)'-vx'(2)/c^2) and t(1)=gamma*(t(1)'-vx'(1)/c^2)
x'(2)=x'(1)=x'(0)
t(2)-t(1)= gamma*(t'(2)-t'(1))-gamma*v/c^2(-v*x'(0)+v*x'(0))
t(2)-t(1)=gamma*(t(2)'-t'(1))
from the reference frame of S' the two events that were at the same reference point in the S prame with not be at the same reference point in the S' frame. hence, x'(1) will not equal x'(2)
t'(2)= gamma*(t(2)-v*x(2)/c^2)
t'(1)=gamma*(t(1)-v*x(2)/c^2)
t'(2)-t'(1)=gamma*(t(2)-t(1))-gamma*v/(c^2)*(x(2)-x(1))
hence , t(2)-t(1) is large than t'(2)-t'(1)
x=gamma*(x'+vt')
Shouldn't you be using +vx'(2)/c^2 etc...
x'(2)=x'(1)=x'(0)
You've proven your result above. I don't understand the purpose of the part below.
  • · Replies 24 ·
  • · Replies 22 ·
